Idle solenoid
Old August 1st, 2011, 09:46 PM
1974 DELTA 88
AZ455's Avatar
Idle solenoid
Well I finally got a tach for the Olds, and was setting the slow idle today when I noticed something that doesn't seem right.
The service manual says to set the slow idle to 650 RPM in drive (solenoid energized) and 550 RPM in park (solenoid de-energized). Well, I set it to 650 RPM in drive by adjusting the solenoid screw, no problems. I then put it in park to adjust to 550 RPM with the carb idle screw and noticed the solenoid doesn't de-energize in park... Was my engine not hot enough or something? It had been running some time, but not driven. What de-energizes the solenoid?
Thanks.
AZ455 is offline
Old August 2nd, 2011, 03:47 AM
Was your A/C on?
MDchanic is offline
Old August 2nd, 2011, 07:08 AM
1974 DELTA 88
AZ455's Avatar
No, vent control in off position.
AZ455 is offline
Old August 2nd, 2011, 07:14 AM
Rickman48's Avatar
I thought the solenoid was for the A/C compressor causing a lower idle when on - and should be set with the switch in the on position!
Rickman48 is offline
Old August 2nd, 2011, 07:18 AM
Where were you in '72?
boondocker's Avatar
X2 ...according to my '71 manual.
boondocker is offline
Old August 2nd, 2011, 07:23 AM
1974 DELTA 88
AZ455's Avatar
According to my manual for the 74 the solenoid energizes with the key in the ON position, which mine does (plunger out against throttle linkage). From how they describe it it only refers to it for setting the slow idle. It says set 550rpm idle solenoid de-energized in park, and 650rpm in drive - solenoid energized.
Mine never de-energizes, so if I set the idle to 650rpm with the solenoid plunger adjustment in drive, once I goto park I'm then idling at 800-900 rpm because the solenoid plunger is still pushing the throttle open some.
Unless it's really just an anti-dieseling solenoid and its supposed to stay energized the whole time until the engine is shut off? It's sort of vague in the manual.
AZ455 is offline
Old August 2nd, 2011, 07:42 AM
Rickman48's Avatar
Does anything change if in the A/C position, blower motor on?
Old August 2nd, 2011, 07:45 AM
1974 DELTA 88
AZ455's Avatar
No, nothing different with A/C on or off, trans in or out of gear, or engine temp.
AZ455 is offline
boondocker's Avatar
Here's a explanation that might help...
http://www.corvetteactioncenter.com/...-solenoid.html
Old August 2nd, 2011, 07:46 AM
1974 DELTA 88
AZ455's Avatar
Ah, so it is just to prevent dieseling. I suspected as much, but the name they give it misled me to think it'd change the idle as the car was running.
I ended up setting the idle to the 550 rpm in park they suggest, though in gear it drops down a bit more, but the engine seems to not mind the low idle speed... and it sure sound good that low...
AZ455 is offline
Old August 2nd, 2011, 07:57 AM
Rickman48's Avatar
And I don't think you have to worry too much about high idle with the choke on - in Arizona!
What's the coldest it gets there - like 40?
Old August 2nd, 2011, 08:00 AM
1974 DELTA 88
AZ455's Avatar
Well, Arizona's a big state with very different elevations/climates throughout it..
In my part of the state, probably no colder than 15 degrees in an average winter. No hotter than the 90s in an average summer.
AZ455 is offline
Old August 2nd, 2011, 08:06 AM
1974 DELTA 88
AZ455's Avatar
So does anyone see any reasons that I shouldn't leave the in-drive idle at around 400rpm? That's with 550 in park.
Runs good, sounds good.
AZ455 is offline
Old August 2nd, 2011, 08:17 AM
Rickman48's Avatar
If it works, do it!
Old August 2nd, 2011, 09:19 AM
Junkman's Avatar
The proper way to set this is to set the idle with the solenoid energized at the speed it calls for. Then disconnect the solenoid, and set the idle speed with the choke fully warmed and off at the 550. Once you have these two set, you can adjust the idle screws on the carburetor for the best idle, and then reset the other two. If the carburetor has idle screw caps, you can pry them off for a better mixture. Just don't tell the emission police that I suggested this. Then check everything one more time after you take the car for a drive around the block to settle out any "alignment" issues. If the air cleaner element is clogged, it is going to mess with your idle speed, so this is one more reason to replace a dirty air filter. If you experience "dieseling" when you shut the car off, then leave it in drive when you turn the key to the off position, and the "dieseling" problem is solved.
Junkman is offline
73rocketship
July 6th, 2012 06:45 AM
67442HT
July 14th, 2011 04:35 PM
roomer
July 11th, 2011 06:36 AM
68conv455
September 21st, 2009 10:48 AM
Chumley
April 11th, 2008 07:08 PM
Quick Reply: Idle solenoid
