I hesitate to mention her hesitation...
Old May 31st, 2011, 04:53 PM
Got wood? I do! (an '89)
auto_editor's Avatar
Well, she's hit the 170,000 miles mark with her engine and transmission never needing any attention, but that lower-end banging thing (and all of the other signs I've mentioned in earlier posts) points to the fact that my luck is going to change.
Until then--seeing as I'd have to completely re-do or replace her 307 I might as well keep nursing it along for as long as I can--there is really only one (I think) issue that's REALLY worrying me: hesitation.
I can drive around town no problem, but after something like five minutes of steady expressway-style driving (even under 45 mph) as soon as I come to a stop her engine starts stumbling, the oil light flickers, and she seems dead-set on stalling.
Start rolling again and the light goes out but the gas pedal feels like it's got a towel under it and throttle response is jerky at best. But after you've putt-putted along for a couple blocks, everything just goes back to golden again on its own.
Is it overheating? Is it a carb problem? Is it yet another sign that I need to keep my AAA membership current because my "borrowed" time is about up? I need to know!
I'm already not taking the freeway anywhere and driving her at a pace even Miss Daisy would call too slow. I've had the coolant replaced and am changing the oil every 1k miles or so in the hopes that I can eke a few more weeks (or more!) out of her. And apart from this hesitation issue, it seems to be working.
If that's "just what happens before the big kablooey" I guess that's terrible but understandable. It's the NOT KNOWING part that's getting to me.
So thanks, as usual, in advance...
auto_editor is offline
Old May 31st, 2011, 08:13 PM
Certifiable car addict...
GTI_Guru's Avatar
with 170K on an original engine, I would check your timing chain. Easily done with rocking the crank back and forth with the distributor cap off to see how much play there is. Those engines have a nylon covered top gear (noise reduction) and when they start coming apart, the pieces can clog the oil pickup screen in addition to causing funny/strange performance issues.
Here's a detailed link to check it yourself
http://www.misterfixit.com/chanslop.htm
If that's all good, then it's possibly an ignition or carburation issue. Usually, you'll get a lot more noise or oil pressure issue (idiot light on at all times at idle) if there's something wrong with a bottom end. With proper maintenance and easy driving habits, there's no reason a bottom end can't go well over 200K miles. The nylon timing gear is usually the weak link. I've spun several of those off older V8's over the years.
-Jeff
GTI_Guru is offline
Old May 31st, 2011, 10:59 PM
johnstonad's Avatar
I checked the link GTI_Guru. And it is really detailed one. I've learned to fix the issue for it. Thanks.
johnstonad is offline
Old June 1st, 2011, 03:59 AM
Destructor's Avatar
At some point GM stopped using nylon, at least Chevy did. When I replaced the intake gasket on my 88 Caprice's 305 I was able to see the top gear from the valley (through an oil hole) it was all steel, though it is still a good idea to check the chain. I sold the car to a friend and I know he took it to over 150 K. It would be interesting to see if it is nylon or when GM switched to steel.
Destructor is offline
64Olds98
March 31st, 2016 08:34 PM
aliensatemybuick
November 10th, 2011 07:49 PM
magwa
August 6th, 2011 01:41 PM
BIGJERR
November 18th, 2009 02:51 PM
dingusboy
July 1st, 2009 11:08 AM
Quick Reply: I hesitate to mention her hesitation...
