Ever Had Oil Leaking Around The Drain Plug?
Old Aug 29, 2009 | 03:42 PM
Dan Wirth's Avatar
My oil drain plug is as tight as I can get it (don't want to strip it out). And oil leaks from it. (About a drop a day- not a big deal). I know an obvious answer is a re-tap and/or use a larger plug. However, I was talking to a mechanic the other day who recommended I use a nylon washer to see if this would better seat the plug and fix the leak. Has anyone had good results with that approach?
Old Aug 29, 2009 | 05:24 PM
Bluevista's Avatar
Registered
Those oil pan drain fitting type threads never seal that well for some reason?
Oil pan drain plug washers /gaskets are what are normally used. I have a whole box of the copper ones I got from NAPA. The soft metal type really should only be used once, a few cents each when I bought them a hundred years ago.
There are several different type, saw the nylon type many times when I was a grease monkey.
Try one at the next oil change, can't hurt, the worst that can happen is that it will still drip.
Don't overtighten the drain plug to try and stop the leak, it never works.
Old Aug 29, 2009 | 09:45 PM
Dan Wirth's Avatar
Thanks Bluevista, will give it a try. May even go to Napa for the copper type as well and will see how each works out.
Old Aug 29, 2009 | 10:48 PM
wolfman98's Avatar
Captain of my ship
I had similar problem and ordered a new plug which came with the nylon gasket which worked just fine , Either one should solve your problem.
Old Aug 30, 2009 | 05:00 AM
My442's Avatar
GM dealers sell a drain plug that has a gasket molded into the center.
Best one I have ever used.
Old Aug 30, 2009 | 05:31 AM
bjtstarfire's Avatar
I made one out of a piece of thin scrap viton rubber. Works good and it is reusable.
Old Aug 30, 2009 | 10:40 AM
Lady72nRob71's Avatar
I have used these gaskets over and over again. The little molded in o-ring is great. The bottom exterior of my pan is totally dry!
Old Aug 31, 2009 | 06:30 AM
You can get the drain plug gaskets with inserted rubber o-rings at your local auto parts store for a dollar or so. Don't waste your money at a GM dealership.
Old Aug 31, 2009 | 03:50 PM
Dan Wirth's Avatar
Sounds like quite a few viable options to choose from. The drain plug with o-ring sounds like the ticket. I will check with my auto store for one.
Thanks for your replies.
Dan
Old Aug 31, 2009 | 06:37 PM
Redog's Avatar
True on the overtightening thing.
I took the car to a shop between mech's and they know I like to change my own oil, so they put that plug on super tight and I couldn't budge it. I was pushing soooo hard, my legs were going up with every try
Ended up taking it to a shop and the plug had to be replaced. I had an extra one on hand
Old Sep 1, 2009 | 06:23 AM
wolfman98's Avatar
Captain of my ship
My old plug did not have any kind of o-ring or nylon seal or even copper gasket and was so tight i had to use a pipe over the wrench to get it off. Even being so tight there was still small drips of oil on and around it. that's why I ordered a new one and it came with the nylon gasket , they said just put it on snug and don't overtighten. it sealed fine and never had any oil on or around the plug.
Old Sep 1, 2009 | 02:34 PM
Dan Wirth's Avatar
It sounds like both approaches will work: a plug with O-ring or Plug with nylon gasket.
Thanks again for your replies.
Dan
Old Oct 16, 2009 | 03:56 PM
Joeypete's Avatar
Ha! That is too funny. Last time I changed the oil on my wagon I pulled the old gasket off the bolt because it was cracked. Didn't even occur to me that it was there for a reason My pan drips now, but I'll put a gasket on when I change the oil.
Old Oct 18, 2009 | 12:24 AM
442much's Avatar
Yes but I saw a doctor and now I'm cured sorry
Old Oct 18, 2009 | 07:31 AM
citcapp's Avatar
Thats and early morning wake up
Old Oct 18, 2009 | 07:27 PM
cutlassgal's Avatar
Cutlass Lover
God I hate it when my drain plug leaks!!!
Napoleon Solo
Dec 11, 2014 08:57 PM
Johnny HR
Apr 23, 2013 12:44 PM
tpawlik
May 8, 2011 08:19 PM
Olds64
Feb 17, 2009 01:20 PM
prawnman88
Apr 27, 2007 07:54 PM
