Ever Had Oil Leaking Around The Drain Plug?
Old August 29th, 2009, 03:42 PM
Dan Wirth's Avatar
My oil drain plug is as tight as I can get it (don't want to strip it out). And oil leaks from it. (About a drop a day- not a big deal). I know an obvious answer is a re-tap and/or use a larger plug. However, I was talking to a mechanic the other day who recommended I use a nylon washer to see if this would better seat the plug and fix the leak. Has anyone had good results with that approach?
Dan Wirth is offline
Old August 29th, 2009, 05:24 PM
Registered
Bluevista's Avatar
Those oil pan drain fitting type threads never seal that well for some reason?
Oil pan drain plug washers /gaskets are what are normally used. I have a whole box of the copper ones I got from NAPA. The soft metal type really should only be used once, a few cents each when I bought them a hundred years ago.
There are several different type, saw the nylon type many times when I was a grease monkey.
Try one at the next oil change, can't hurt, the worst that can happen is that it will still drip.
Don't overtighten the drain plug to try and stop the leak, it never works.
Bluevista is offline
Old August 29th, 2009, 09:45 PM
Dan Wirth's Avatar
Thanks Bluevista, will give it a try. May even go to Napa for the copper type as well and will see how each works out.
Old August 29th, 2009, 10:48 PM
Captain of my ship
wolfman98's Avatar
I had similar problem and ordered a new plug which came with the nylon gasket which worked just fine , Either one should solve your problem.
wolfman98 is offline
Old August 30th, 2009, 05:00 AM
My442's Avatar
GM dealers sell a drain plug that has a gasket molded into the center.
Best one I have ever used.
My442 is offline
Old August 30th, 2009, 05:31 AM
bjtstarfire's Avatar
I made one out of a piece of thin scrap viton rubber. Works good and it is reusable.
bjtstarfire is offline
Old August 30th, 2009, 10:40 AM
Lady72nRob71's Avatar
I have used these gaskets over and over again. The little molded in o-ring is great. The bottom exterior of my pan is totally dry!
Lady72nRob71 is offline
Old August 31st, 2009, 06:30 AM
You can get the drain plug gaskets with inserted rubber o-rings at your local auto parts store for a dollar or so. Don't waste your money at a GM dealership.
Olds64 is online now
Old August 31st, 2009, 03:50 PM
Dan Wirth's Avatar
Sounds like quite a few viable options to choose from. The drain plug with o-ring sounds like the ticket. I will check with my auto store for one.
Thanks for your replies.
Dan
Old August 31st, 2009, 06:37 PM
Redog's Avatar
True on the overtightening thing.
I took the car to a shop between mech's and they know I like to change my own oil, so they put that plug on super tight and I couldn't budge it. I was pushing soooo hard, my legs were going up with every try
Ended up taking it to a shop and the plug had to be replaced. I had an extra one on hand
Redog is offline
Old September 1st, 2009, 06:23 AM
Captain of my ship
wolfman98's Avatar
My old plug did not have any kind of o-ring or nylon seal or even copper gasket and was so tight i had to use a pipe over the wrench to get it off. Even being so tight there was still small drips of oil on and around it. that's why I ordered a new one and it came with the nylon gasket , they said just put it on snug and don't overtighten. it sealed fine and never had any oil on or around the plug.
Old September 1st, 2009, 02:34 PM
Dan Wirth's Avatar
It sounds like both approaches will work: a plug with O-ring or Plug with nylon gasket.
Thanks again for your replies.
Dan
Old October 16th, 2009, 03:56 PM
Joeypete's Avatar
Ha! That is too funny. Last time I changed the oil on my wagon I pulled the old gasket off the bolt because it was cracked. Didn't even occur to me that it was there for a reason My pan drips now, but I'll put a gasket on when I change the oil.
Joeypete is offline
Old October 18th, 2009, 12:24 AM
442much's Avatar
Yes but I saw a doctor and now I'm cured sorry
442much is offline
Old October 18th, 2009, 07:31 AM
citcapp's Avatar
Thats and early morning wake up
citcapp is offline
Old October 18th, 2009, 07:27 PM
Cutlass Lover
cutlassgal's Avatar
God I hate it when my drain plug leaks!!!
cutlassgal is offline
Napoleon Solo
December 11th, 2014 08:57 PM
Johnny HR
April 23rd, 2013 12:44 PM
tpawlik
May 8th, 2011 08:19 PM
Olds64
February 17th, 2009 01:20 PM
prawnman88
April 27th, 2007 07:54 PM
Quick Reply: Ever Had Oil Leaking Around The Drain Plug?
