What crank pulley do I use. It's a 330 I think 64
Old February 8th, 2022, 12:07 PM
Ral
Ral's Avatar
I've got a 64 330 water pump and a 64 crank pulley with the water pump pulley being off because the crank pulley doesn't come out far enough.. like an 8th of an inch.. I was told it's a hi compression 330 out of a 64 f85 but I'm not sure. All other parts I've been buying have been for a 64 f85. What cars and with what motors came without a harmonic balancer
Ral is offline
Old February 8th, 2022, 12:23 PM
brianbeez67's Avatar
Odds are, no cars came without a harmonic balancer. But an 8th of an inch is not much. I know that the water pumps have different shaft lenght’s depending if Air conditioning or not. If just that small of a offset, ? Gasket thickness ? Good luck
brianbeez67 is offline
Old February 8th, 2022, 12:30 PM
Ral
Ral's Avatar
What crank pulley or water pump do I use for my 64 330
I ve got a 64 330 with the hub no harmonic balancer and I'm using a water pump from a 64 f85. My crank pulley sets farther back that my water pump by about a 1/4in. Is the water pump need to be for a jetstar or is there 2 different depth crank pulleys? Lmk its all this thing needs thanks
Ral is offline
Old February 8th, 2022, 02:24 PM
REO442's Avatar
My stock 64 has a one-year-only water pump, the lower hose is on the driver's side. Maybe your 65 pump has slightly different geometry. Hope this helps.
REO442 is offline
Old February 8th, 2022, 04:33 PM
2blu442's Avatar
I think you could use the 1964-66 pulleys for an engine without a damper. Be sure you put the correct 1964 timing marker on the engine. Or be prepared to create new marks on the balancer to time it from.
John
2blu442 is offline
Old February 8th, 2022, 04:48 PM
Ozzie's Avatar
Which pulleys (crank or water pump) align correctly with the alternator?
Ozzie is offline
Old February 8th, 2022, 05:07 PM
Ozzie's Avatar
The 1964 Oldsmobile Service manual says that a harmonic balancer is used on all cars equipped with a 4 bbl. carburetor. Hence, I "assume" the 2 bbl. wasn't. This was for the series 30-33 with the V-8. See page 3-155
Ozzie is offline
Old February 8th, 2022, 05:42 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Somebody will speak up but I think I have read on here these are one only items for 64.
redoldsman is offline
Old February 8th, 2022, 06:16 PM
2blu442's Avatar
Here's some pictures of the 1964 330 timing tab location with the 1964 only water pump. Then pictures of a 1968 350 timing tab, which was used from 1965 on. I know your asking about pulleys but I think this is an additional thing you need to be aware of. If you put the newer timing tab on the drivers side you may need to scribe or paint the balancer for the correct location of TDC.
1964 timing tab
1964 Timing tab
1964 only 330 water pump
1965 and newer timing tab location
2blu442 is offline
Old February 8th, 2022, 06:48 PM
The Rocket Astronomer
lunaboy's Avatar
looks like a low compression smaller 64 330 dampner and dont think thats a 64 waterpump for cutlass.
changing the dampner wont fix it but changing the waterpump should.
lunaboy is offline
Old February 9th, 2022, 10:35 AM
The 1964 hub and balancer are unique to 1964 due to the passenger side timing tab. The TDC mark is obviously in a different place as compared to those on later motors. The mounting face that the pulley attaches to is the same distance from the front cover as it is on any other 1964-1990 Olds motor.
joe_padavano is online now
Old February 9th, 2022, 10:40 AM
I merged your identical threads. It is neither necessary nor in your best interest to post the same question multiple times. You'll get a better answer sooner if all responses are kept in the same thread.
Old February 12th, 2022, 08:17 PM
2blu442's Avatar
Have you located a set of pulleys yet? Since Joe verified the balancer you have is the same thickness as a damper/balancer combination then you need to get a set of pulleys that will match up to your power steering pump pulley and the depth of the water pump.
2blu442 is offline
Ral
February 8th, 2022 07:51 AM
195
October 23rd, 2013 08:50 PM
Bigolds
July 12th, 2011 07:36 AM
pontiac1
December 24th, 2009 07:25 PM
Droptop
July 7th, 2007 06:16 PM
Quick Reply: What crank pulley do I use. It's a 330 I think 64
