Weird whining/squeal noise
Old November 16th, 2011, 07:25 PM
hunter's Avatar
Here's a weird one
Frequently I get a whining/squeal noise from the engine bay
This happens when I release the throttle at all, even while going straight. In sport mode it becomes VERY loud, even at idle.
Is this power steering fluid? It isn't a belt or pulley squeal, rather than a Weee-eee-e-e-ee-e-e-eeeeeeee (like a blower kind of haha)
If I release the throttle it starts, but when I hit it at all it stops
It's been doing this for a long time too - It stops when I accelerate, starts when I release the throttle - not so much the brakes.
It sounds like an electronic noise too, but it's from the engine, if that helps you imagine the noise, it's loud, almost thought it was the radio the first time it happened when I used to drive it around the driveway before I got it
In sport it sounds much worse. Remember this is only on releasing the throttle when it starts, weird... And once it starts it continues until I accelerate again, and today I had it in park running, it was making the noise, opened the hood, it becomes louder... It was dark so I'm not sure where it was coming from, yet it seems like from a google search it's related to power steering?
Wheels were straight too, it's weird stuff...
hunter is offline
Old November 16th, 2011, 07:28 PM
What's "sport mode?"
MDchanic is offline
Old November 16th, 2011, 07:32 PM
hunter's Avatar
"S" on DG shifter
Whatever you want to call it lol
hunter is offline
Old November 16th, 2011, 07:37 PM
enterogue's Avatar
S for second - shifts just 1st and second - sport mode is too modern - it's the PS and is common
enterogue is offline
Old November 16th, 2011, 08:03 PM
"S" is actually for "Super" on Oldsmobiles.
The same gear is merely "2" on those crappy Chebbies .
Oh, yeah... could be the power steering, or could be some other accessory bearing, like the water pump or the alternator. You've got to listen with a mechanic's stethoscope, or a highly tuned rubber hose to find out.
MDchanic is offline
Old November 16th, 2011, 09:20 PM
Rickman48's Avatar
Yeah - super at sucking gas!! And R is for race!!
Hope what you're hearing isn't the front pump on the trans! That'll make noise when you back off the gas!
Rickman48 is offline
Old November 17th, 2011, 03:21 AM
golds56's Avatar
try spraying the belt with brake cleaner while running,dont get any on the paint.it may be just some burnt rubber on the belt and belt dressing sucks,never try belt dressing on a serpentine belt either as it will throw the belt immediately and probably into your face (experienced ).
golds56 is offline
Old November 18th, 2011, 11:10 AM
Jetstar 88's Avatar
I think it may just be the drone of a slightly worn out automatic transmission. My 200,000 miles+ ST300 makes the same group of noises.
Jetstar 88 is offline
Old November 18th, 2011, 11:45 AM
My trans mainly did that in park. In gear, or accelerating it was quiet.
oldcutlass is offline
Odmark
26
April 12th, 2013 06:27 AM
Karpov
August 9th, 2012 05:07 PM
Joffroi
November 3rd, 2011 12:42 PM
Joffroi
October 25th, 2011 06:52 PM
ls442
July 12th, 2009 01:29 PM
Quick Reply: Weird whining/squeal noise
