trunk spatter paint?
Old April 8th, 2009, 06:01 PM
jensenracing77's Avatar
fusick has 3 differant colors available. how would i tell what my car had? does plant location make a difference? mine was a Michigan car. and is the fusick trunk mat a good one. i was told that there are some bad ones out there. i don't figure that fusick would have them if they were not a good one.
jensenracing77 is offline
Old April 8th, 2009, 09:34 PM
csstrux's Avatar
both mine came black with turquoise spatter, not sure what colors the factory called it.
csstrux is offline
Old April 9th, 2009, 07:37 AM
68Tom's Avatar
I just ordered a quart from The Parts Place. They claim to have the original formula GM used. I've heard good things about it.
In terms of the color in your trunk, have you had your car completely blasted or stripped? If so, there's no way to tell what you had. I guess you could start searching other VIN#s close to yours and ask the person what color their trunk paint it. Otherwise, it could either be gray & white or black & turquoise. I found the current paint in my trunk to look more like gray & turquoise, so I opted for the black & turquoise splatter paint. Plus, this matches the trunk mats & spare tire cover better, so that's what I went with.
I should know what it looks like in early May, so if you can wait, I'll let you know.
I also JUST ordered the trunk mat from Fusick. Most of their other stuff is quality, so I don't think it'd be junk. However, if it's not to your liking, you can always return it to them without issue. Give them a call. They're always helpful on the phone and express your concerns.
68Tom is offline
Old April 9th, 2009, 11:44 AM
csstrux's Avatar
Cut one apart, the other is partially blasted, but slated to get cut apart. I have to fix the rust, along with everything else b4 I can drive it. GRRR. Some day I'll actually buy one thats done.
csstrux is offline
Old April 9th, 2009, 11:48 AM
68Tom's Avatar
Oh, I know the feeling, Chad. I actually wonder what it's like to have an old car and be able to drive it regularly. I guess then we wouldn't be here on the boards as much then tho....
68Tom is offline
Jamesbo
Paint
June 13th, 2020 09:02 PM
Flye
Paint
March 30th, 2012 06:32 AM
car_designer
Paint
December 6th, 2010 02:51 AM
Phil Glass
March 4th, 2010 06:21 PM
Chumley
August 29th, 2009 04:14 AM
Quick Reply: trunk spatter paint?
