Saw this Roadster the other day
Went to get some gas a while back and this was parked in front of me. Owner claims it's an all aluminum 215, but from the Lotus racing team. Pretty cool car!
Well, that's actually an Olds 215 as opposed to a Buford or Rover motor (the heads and valve covers are different on the Olds 215s). The other interesting thing is that the alternator is on the opposite side from factory. The stock alternator bracket mounts to the passenger side.
By the way, here's a 1926 Model T Roadster:
I'm curious, how many 215's did Oldsmobile build?. I understand the main difference between Olds and Buick versions were Olds had 5 bolt heads and Buicks had 4.
Rover engines used a different casting method, although I don't know how to tell the difference between blocks and heads.
Cars like the beautiful example shown were often seen at British hot rod shows with Rover V8 engines, but for looks nothing beat a dressed up Flathead Ford V8 IMO>
Roger.
Roger.
According to the definition of a roadster, the T bucket is a roadster. Most T buckets were made from roadster bodies, some were made from the front half of a touring car. T bucket is a term used to describe the appearance of the body looking like a "bucket". It is not the actual definition of the car.
The main point of my post was that the owner stated the engine was one of a few performance enhanced engines used by Lotus racing. He supposedly has done a lot of research to this fact, which apparently makes it quite rare.
The car is actually called a Roadster Pickup.
Other than the color, I think this is a cool car whether it is a roadster or not. I assume this a local Granbury guy. Since it is Olds powered, he should come to the show next April. I don't know if there is a class for him but who cares.
The Olds heads use five bolt valve covers, vs four bolt for Buick/Rover, and the valve cover mounting surface on the Olds is parallel to the deck of the block. On the Buick/Rover heads the valve cover mounting surface is nearly parallel to the carb mounting flange, just like nailhead Buick motors.
The biggest difference is the number of head bolts. Olds heads use SIX bolts around each cylinder (as can be seen in the third photo above). Buicks use five. Rover started with five and went to four, which actually provides a better seal since the clamping loads are symmetric now.
I don't have the breakdown of production by Olds vs. Buick/Pontiac, but GM built about 750,000 of these motors in three years of production. To give you an idea of production scale differences, that's more motors built in three years than Rover built in three DECADES! Rover did do a couple of nice mods, however. The first is the change to sand casting as you note above. This solved the casting porosity problems GM was having. The second is the introduction of cross-bolted mains (just like a 427 side-oiler) on the 4.0 and 4.6 liter versions. I've got a 4.6 short block that will get Olds heads and a T5 trans for my 62 wagon.
Mickey Thompson also built 215s (Buick versions) to race at Indy in the early 1960s. Jim Hall used 215s in his Chaparral I race cars. They really are the SBC of England.
Actually, the difference between Olds 215s and other BOPR motors (Buick, Olds, Pontiac, Rover) is the design of the heads. This website provides great comparison photos of Olds heads next to Buick and Rover heads. In these photos, the third from the left is Olds, the rest are Buick and Rover.
Thanks Joe, the pictures give me a much better idea of the differences. I guess the middle head is from a Olds, the second from the right from a Buick an the rest are Rover versions?.
To put that in perspective, in 1966 the British automotive industry (which was around its peak production) managed to make something like 1.6 million cars, trucks, buses and vans. The Chevrolet division of GM managed to make rather more cars called Chevrolets, not including other products like Corvettes, Corvairs, Chevy II, as well as various trucks buses and vans.
Yeah, he's full of crap. I don't think Lotus ever did anything with these motors. He's thinking of the Repco Formula 1 motors that were based on the Olds 215 block. The motor in the T-bucket above has NOTHING to do with those.
Lotus developed several European engines for road use, possibly most successfully the dohc version of the Fords Kent engine as used in the Lotus Elan, Lotus Cortina and Escort Twin Cam/
More like the Big block in terms of relative size, remember anything over 2 liters was a big engine by our standards.
The big deal with the Rover engine was weight, shoehorning an iron engine that size into something designed to accept a 4 cylinder would have upset the cars balance terribly.
Strangely it was cheaper to buy a small block American engine than a Rover engine over here, and parts for them were cheaper too.
Roger.
47 Convertible
March 18th, 2013 09:03 AM
