Replacing Convertible Top 73 Delta 88
Just curious if anyone has replaced a top. Ive read that the Scissor tops can be a PITA to do. I know shops want wuite a bit in labor to install. Just wondering if its something I shouls attempt or take to a shop.
Have you ever replaced a convertible top before?
Have you ever replaced a scissor-top convertible top before?
I needed the top replaced on a '75 Delta 88 convertible I owned back in the 1990s. Having never done anything like this before, there was no way I would have tried it myself. Some things are worth leaving to the professionals.
I have done three and it is really not that hard. It takes patients and two people to do it well. Replacment tops come with small holes where the rear hold down strips go. I recommend you do the top, pads, well liner, and the tack strips in the top all at the same time. Get a good power stapler and take your time. A warm place to do it helps. about a 6 hour job. If you have one on it now make measurements from the bow above the back window to the body and makes notes of that. I also recommend new seals at least at the front header.
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
kitfoxdave
August 31st, 2012 11:14 AM
MASH4077
March 1st, 2011 11:57 AM
Olds luvr
December 2nd, 2010 08:26 AM
