Reconditioning Inner Wheel Wells
Old May 5th, 2014, 09:23 PM
Boilerz25's Avatar
I pulled my black inner wheel wells and cleaned them thoroughly but they still have a faded appearance. Anyone know what I can use to restore to stock appearance? I guess a temporary solution would be Armor All or similar but I was wondering if there is a paint or stain that will restore the original color. Appreciate the advice.
Sean
Boilerz25 is offline
Old May 5th, 2014, 09:47 PM
dnmfranco's Avatar
I cleaned mine w good cleaning solution and scotch guard.
Then vinyl prepped them and hit w a few coats of Landau Black
they came out great
dnmfranco is offline
Old May 5th, 2014, 10:10 PM
Noooo, DON'T armor all them.
Once they're clean (really clean) I've found a product that works extremely well to restore black plastic - it's called Dupli Color Vinyl and Fabric Dye. I've also used Duplicolor Trim Paint (semi gloss) on other plastic parts like transmission inspection cover with really good results.
You'll need to really degrease and clean the engine side parts super clean. There's a lot of oils on the plastic you won't see. Use TSP to clean and a brillo pad to lightly scuff the plastic, then lightly spray 2 coats as per instructions.
I used it on my air dam restoration and it came out great!
BEFORE
WASHED AND CLEAN (note faded areas)
AFTER PREP and SPRAY with ADHESION PROMOTER & VINYL DYE
One thing that's really important for the inner liner because it's all plastic - clean really well, then spray with an adhesion promoter. Finish with either of the duplicolor products I mentioned. I know you'll be amazed at the results.
Allan R is offline
Old May 6th, 2014, 06:16 AM
Boilerz25's Avatar
Thanks Allan. The air dam looks great.
Sean
Phantomhouse
April 7th, 2015 03:26 PM
1k442
November 27th, 2013 11:46 AM
1k442
November 15th, 2013 07:00 AM
5hundo
Body work
August 13th, 2009 12:57 PM
5hundo
June 18th, 2009 11:13 AM
Quick Reply: Reconditioning Inner Wheel Wells
