Rear coil springs
Old August 4th, 2010, 01:52 PM
dhartley72's Avatar
Rear coil springs
any ideals on what will make my cutlass sit back at stock level......mine kinda sagg in the back and i want it to sit up level ...i thought maybe it would be the shocks... i changed them out and it still sits the same.....so my next guess is the coil springs....will the coil springs at the local auto parts store work fine???????
dhartley72 is offline
Old August 4th, 2010, 01:56 PM
dhartley72's Avatar
here's a pic
Old August 4th, 2010, 04:32 PM
BobsW32
Bobsw32's Avatar
Put a set of air bags in the springs is the easiest and cheapest and then is adjustable. You can replace the springs.......It is very easy to do a bit more costly unless you find a used set that would be at the right height you want
Bobsw32 is offline
Old August 4th, 2010, 06:31 PM
Lady72nRob71's Avatar
The Moog springs should work fine - available at rockauto or your local shops.
I changed mine to the Moog HD versions and the rear sits about an inch higher than it would with some new standard springs.
Springs will sag over time - not good for sudden dips in the road.
Lady72nRob71 is offline
Old August 6th, 2010, 08:54 AM
dhartley72's Avatar
thanks headed to the parts store now
Old August 7th, 2010, 05:14 AM
Let us know what you get and how they work out.
Be sure to get new insulators, also (mount at top sides only).
The nice thing is that the springs change out easily, and it would be easy to exchange them for a different set if you are not happy with the height or ride.
Here is some replacement info, if it will help ya:
https://classicoldsmobile.com/forums...tml#post167869
Old August 7th, 2010, 08:28 AM
Blk71SX's Avatar
springs hold up the car, shocks control the rebound.
if you can compress the shocks by hand how can they hold up a 2 ton automobile?
I'm talking regular shocks, not spring or air assisted
Blk71SX is offline
RetroRanger
February 25th, 2014 05:04 PM
Bobac455
July 12th, 2013 06:04 AM
Daniel2008
April 17th, 2011 10:40 PM
Lady72nRob71
August 7th, 2009 11:52 AM
cola
June 18th, 2008 08:34 PM
Quick Reply: Rear coil springs
