Pin in shift gear (floor console)
Pin in shift handle of 1974 cutlass supreme
I was able to get the shift **** (floor console) off, it screws off. I am having problems getting the little pin that holds the piece you pull up to change from park to drive etc out...any suggestions how to get it out
Pin in floor shift gear 1974 cutlass supreme
Only one such inquiry is usually necessary.... looks like 3 or 4 today?
I have used a pin punch of the appropriate diameter, with a backup "anvil" of whatever is massive and handy if needed. It's a tiny pin and usually comes right out.
I merged your two identical threads.
FYI, it is neither necessary nor in your own best interest to start multiple posts in multiple sub-forums with the exact same question. We all read the same posts. More importantly, you'll get the best answer if all responses are kept in the same thread, so that incorrect information can be caught and corrected more quickly.
hvysupreme
February 18th, 2017 12:40 PM
Alocatelli
December 10th, 2012 07:49 AM
