Oai hood
Old February 5th, 2019, 05:47 AM
kbdecatur's Avatar
Oai hood
Will the rear edge hood molding on a stock hood fit on a oai hood? The reason I’m asking is because the rear of the stock hood seems way thinner than the rear on the oai hood. It’s a Thornton’s hood and it’s a 72 cutlass. Thanks in advance.
kbdecatur is offline
Old February 5th, 2019, 06:19 AM
Dockolds's Avatar
Nope---your assumption is correct--Hood trim on the cowl edge of the OAI hood has the "Wider opening" and requires a different rear hood trim than the stock steel hood.
Dockolds is offline
Old February 5th, 2019, 06:23 AM
kbdecatur's Avatar
Oai hood
So where do I find one that fit correctly?
Old February 5th, 2019, 06:32 AM
Dockolds's Avatar
I don't think they repop these, but I could be mistaken.
Should be able to find a good used one on this site from someone here or on Ebay.
Fusick, Oldsparts.com or The Parts Place might have a used/reconditioned one.
Dockolds is offline
Old February 5th, 2019, 06:34 AM
kbdecatur's Avatar
Thanks!!
Old February 5th, 2019, 07:10 AM
kbdecatur's Avatar
Originally Posted by kbdecatur
Thanks!!
I’ve gotten 2 suggestions and both sounds good. One is to shave some of the material down and the other is to take 2 putty knives and slowly slide and open up as you go. NO SCREWDRIVERS.
Old February 5th, 2019, 07:23 AM
Dockolds's Avatar
Could do that...but sometimes the last inch or two of ends of the trim will "Flare Up" rather noticeably and would not look even with your trim on the fender.
You could put bees wax on the trim gap and the hood...use a plastic or rubber mallet with a piece of homasote board between the mallet and the trim piece and gently hit it to get on. (Typical Glaziers tools for glass FYI).
Dockolds is offline
delete
droptopron's Avatar
I've installed two OAI hoods and both times I used the molding from my stock hood with some gentle persuasion.
droptopron is offline
Old February 5th, 2019, 07:37 AM
Gary
Gary's 2 442-S's Avatar
Originally Posted by droptopron
i've installed two oai hoods and both times i used the molding from my stock hood with some gentle persuasion.
x2
Gary's 2 442-S is offline
Old February 5th, 2019, 07:49 AM
Yes. There is only one real cowl stainless trim piece. Feather the edges of the fibreglass at the back. You might also look to gently widen the stainless trim piece by using a flat blade and carefully applying side to side wedging motions. The trim will fit especially if it's a Thornton hood.
Allan R is offline
Old February 5th, 2019, 11:52 AM
kbdecatur's Avatar
Old February 5th, 2019, 11:53 AM
kbdecatur's Avatar
Originally Posted by Gary's 2 442-S
x2
thanks
Old February 5th, 2019, 12:43 PM
Gary
VC455's Avatar
...I used the molding from my stock hood with some gentle persuasion.
x3
VC455 is offline
Old February 5th, 2019, 01:59 PM
My442's Avatar
Exclamation
For friction fit moldings, I apply a stick lubricant called Door Eaze.
Apply it to the edge, and the trim slides on and does not skive the paint.
Provides rust protection too.
My442 is offline
Old February 5th, 2019, 02:08 PM
jensenracing77's Avatar
I do not think there are two part numbers for this molding? You need to open up the molding a little to get it on. I used two putty knives together and gently pried apart a very little at a time all along the molding till it was easier to slip on.
jensenracing77 is offline
Old February 10th, 2019, 12:20 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
Thanks for the tip,I'm going to try this.
I picked up some Door Ease,have never used it,looks like an interesting multi use product.
w-30dreamin is offline
crank shaft
April 11th, 2019 04:42 PM
kbdecatur
February 6th, 2019 04:09 PM
ELECMAN
August 6th, 2016 10:20 PM
Hot 442
November 17th, 2011 08:49 AM
442Cliff
Body work
July 16th, 2010 08:55 AM
Quick Reply: Oai hood
