Looking to make ram air.
I think that fabricating a 70-72 ram air setup would be an enormous challenge to complete without looking, well..............Ho-made. The '68-69 style would be a lot easier to do and can be done in a fashion to at least look respectable to most car guys. Otherwise I'd be trying to save the cash, or sell some stuff to order the reproduction from Thornton. Just my humble opinion
Its going on a 1969 Cutlass S which has a 73 Delta 88 455ci. The hood is the 1970 442 Hood. Im not sure what I want to do. Im not as familiar with the 68 ram air as the 71-72 ram air. And where can I get the replacement flapper door?
I like this set up not to bad of a price and it will work all the time no vacuum
motor to go bad or hang up http://www.drdecal.com/store/images/rick2.jpg
For just the flapper door,Supercars Unlimited sells just the flapper door.
If you want the entire lid that the flapper door fits into,take your pick of aftermarket suppliers,quite a few carry the whole lid.Fusick,Thornton,Supercars Unlimited and the list goes on.
The real question is, why do you want the flapper door? The only purpose of the door is to reduce engine noise at low speeds and to allow the Thermactor warm air system to heat the inlet for quicker engine warmup on cold days. Hot Rod magazine proved that simply leaving the flapper door out of the air cleaner adapter reduced quarter mile times. Simply fabricate a ring that the foam seal attaches to and you're done.
Bernhard
April 27th, 2013 10:54 PM
canelb52
April 13th, 2013 02:46 PM
WTony
February 20th, 2012 02:05 PM
68cutlassdriver
Body work
February 17th, 2011 11:06 PM
