help
help
I'm new to website I have a 70 cutlass and wonder jf anyone out there can tell me what size bolts I need to buy to pull my engine out from the heads the whole front clip is tore down do its gonna b easy but need to no wat bolts to use and any refereces to where to get a reasonable conversion kit for front end
I don't recall the size off hand, but make sure they are Grade 8 bolts, and not some cheap ones, or you run the risk of them breaking and the engine falling and smashing a foot ot a leg. You can get Grade 8 at any decent Auto Parts store...I have used NAPA.
Ok, I'll cut you some slack...you need the same size as the other one I told you about; 3/8-16 by however long you need.
Thanks fir the slack pilot I appreciate it. Its my first project so just tryin to get as much info as I need but ill cut back on the crazy qjestions and find out. Ur knoledge is being used tho so thanks
ToronadoGuyDenver
Brakes/Hydraulic Systems
March 18th, 2007 02:52 AM
