Dual gate shifter hook up
I bought a 70 cutlass a few months back. The steering column was beat. So I replace the column and got a dual gate shifter. Car was a column **** originally. So the dual gate shifter does not have the brackets to hook to the tranny! So I would like to know where I could get the brackets or if I can make sumthing to work. I have the b&m bracket kit 35498. Will this work?
I don't know about B&M bracket but here is the kit I used to install mine.
http://www.opgi.com/cutlass/1970/dri...shifters/C351/
Use this cable
http://www.opgi.com/cutlass/1970/dri...fters/C240878/
You may have to modify the shift selector lever to get it to shift through all the gears. I did this by cutting it and welding it about 1/2" towards the engine.
[IMG]Bracket by 70cutty, on Flickr[/IMG]
There is some more pictures in that album on flickr that show how it looks on the transmission.
Check out this thread.
https://classicoldsmobile.com/forums...e-shifter.html
Hope this helps
Use this cable
Hope this helps
ah64pilot
May 29th, 2012 03:04 AM
projectheaven
January 8th, 2012 09:17 AM
