compression ration vs psi
Old August 15th, 2015, 07:59 PM
67Rocket's Avatar
Question for you physics majors. I recently checked the compression on the 68 455 engine I am installing. The readings for a cold block with all plugs removed and no carb on the intake were between 190 and 200 psi for each cylinder. How does PSI relate to CR? The engine has C heads with new valves and was bored .030, previous owner was not sure what pistons or head gaskets were used. Thanks to all
67Rocket is offline
Old August 15th, 2015, 08:35 PM
It doesn't.
It relates to CR and cam profile and timing.
Without knowing the details of the cam, it is impossible to suggest an exact cranking compression number.
That being said, your numbers are normal for a '68 engine, and probably represent a high compression engine.
MDchanic is offline
matchek
August 14th, 2012 11:10 AM
at3reg98
June 8th, 2012 07:02 PM
DENT
February 10th, 2012 08:42 AM
coltsneckbob
October 14th, 2010 04:05 PM
shaks 442 clone
Drivetrain/Differentials
September 4th, 2007 08:30 AM
Quick Reply: compression ration vs psi
