'72 U code Supreme exhaust question...
#41
My answer is that you will lose some horsepower just from going from a long tube header to exhaust manifolds. When I was a little younger, I bolted Hedman Headers on my 72 442 with the base 455 and it really woke up the low end and midrange power. That car would just boil the rubber off of the back tires with ease. It has been published that good headers on an Oldsmobile big block are worth 25 Hp or more. With your performance cam, they are even more important.
Rick
Rick
#42
It's been proven time and again. The only saving grace is that the W/Z manifolds have individual runners and are slightly better than the common open log manifolds.
#44
#45
I answered that question in post #22. Do you not believe Mark's dyno results, or is there another reason why you disregarded that answer?
#47
#51
This is long tube vs shortie headers. About 20 HP and 20 ft-lbs difference. Expect manifolds to be even worse.
https://classicoldsmobile.com/forums...eaders-177221/
#52
#53
#55
#58
#61
That's a good point. Lots of people (me, for instance) run engines with bigger than factory cams through factory manifolds. May be leaving a little bit of horsepower on the table, but what the hell, those W/Z's flow well enough.
#62
The '70 Chevelle SS 454 LS-6 had 2" tailpipes factory. But it also had log manifolds. With that 224/234 cam I would run 2 1/2" pipes back to the mufflers even if you had to neck down the head pipe to fit the W&Z manifolds. After the mufflers you should run 2 1/4" tailpipes. Finally you'll have to neck down the exit to bolt on the trumpets. Does anyone make a 2 1/4" chrome trumpet?
#63
#64
Before mandrel-bent A-body tailpipes were readily available, I would use the 2.25" pre-bent pipes from a 1970 GTO. With a little work, they line up with the bumper cutouts. The OEM trumpets will slide into a 2.25" pipe.
Hdmike444
August 26th, 2019 04:21 PM
