'70 Cutlass-Tips for rear shock removal.
Old May 28th, 2019, 11:13 AM
jpatfarrell's Avatar
Hello all,
Trying to replace the rear shock abosrbors on my '70 cutlass. I cannot get the upper nuts off on the right rear shock. I’ve loosened the two bolts about half way and the nuts on both bolts are now stuck and I can't get them off. The access to the upper nuts is very limited and I can’t seem to get a wrench to hold the nut so that I can remove the bolt the rest of the way. Can't get good enough access to hold a wrench in place on the upper nut. When I put a lot of pressure on the wrench on the bolt, the wrench on the upper nut just pops off.
I've soaked them with penatrating oil.
Any tips would be appreciated.
thanks,
Pat
jpatfarrell is offline
Old May 28th, 2019, 12:21 PM
442Harv's Avatar
Can you get some type cut of tool, hacksaw, sawzal, or cut of grinder, then use new bolts. Are you sure , you can't get a box end wrench on it?
442Harv is offline
Old May 28th, 2019, 12:40 PM
same but different
don71's Avatar
Do you have another choice of wrench to try on top? Or any sacrificial cheap wrench to heat up and bend to your liking?
You can do this, good luck.
don71 is offline
Old May 28th, 2019, 12:41 PM
Thanks for the reply.
I can get a box wrench on the nuts but I can't get my hand up there to hold it with any force while I turn the bolt with the other hand at the same time.
The box wrench on tops turns with the nut and then pops off.
I don't think there would be room to cut the bolts.
Old May 28th, 2019, 12:44 PM
delete
droptopron's Avatar
Can you hold it with a vice grip?
droptopron is offline
Old May 28th, 2019, 12:51 PM
I tried to get a small vice grip on the nut but there was not enough room and the angle was not good. Maybe I can hold the box wrench with the vice grips.....thanks, that is a good idea.
Old May 28th, 2019, 06:12 PM
Schurkey's Avatar
Impact wrench.
Schurkey is offline
Old May 30th, 2019, 04:01 AM
toymobile's Avatar
Try a 13 mm wrench 6 point it is smaller than the 1/2 wedge something between the wrench and the body.
If you have any wiggle room try a big pair of vice grips and brake then off.
Good luck.
toymobile is offline
Old May 30th, 2019, 05:26 AM
Thank you....I'll give it a try.
DewChugr
July 30th, 2014 02:07 PM
CyberCholo
Suspension & Handling
15
April 13th, 2014 05:26 PM
foo
October 28th, 2012 07:01 AM
sicky olds
March 1st, 2012 08:44 PM
jaunty75
20
August 11th, 2009 04:02 PM
Quick Reply: '70 Cutlass-Tips for rear shock removal.
