70 350 4 Barrel - Vacuume line Routings
Does anyone know the proper factory vacuum line routings for a 1970 Cutlass 350 4 barrel, automatic with AC (Pics, factory illustrations..) thanks in advance
Vista, lot of these guys probably aren't even aware the manuals exist.
Then there's guys like me who are obsessed with having them!
Right now I'm on the lookout for a nice 55 and 56, and anything 49-earlier. The older shop books are not that easy to find, and I sometimes hesitate on getting one, thinking I should leave it for someone who actually owns one of the cars.
Bill Sandy had a neat writeup about service literature in JWO this month.
Del, for those hoses installed at the engine assembly plant, you need the 1970 Engine Assembly Manual I sell (I know you're already considering this). For hoses installed at final assembly, you need the assembly manual everyone else sells.
Thanks, I have the final assembly manual and I am aware of them, as well as service books.. I now have a 71 Service manual , which has helping to confirm my routings are correct, which is all I wanted to do….
Which brings up the question of what is "proper" routing? If you have all the proper doodads the factory installed, and if they all work properly, and if you want them to continue to work the way Olds intended (which isn't necessarily the best way), then you can plumb it just like the factory did. If any one of those is not true, then the "proper" plumbing will be different.
63 F85 Cutlass
February 8th, 2015 03:20 PM
