68 Rally Tach & Clock
I have a Rally Tach & Clock on my 68 442 and was wondering if there is a way to turn off the clock (hopefully just by disconnecting a wire) when i am letting the car sit for long periods of time and if so how do i do it.
Why would you want to? The clock draws a minimal amount of current, it would take months of sitting before the battery becomes discharged enough to affect starting.
You could pull the fuse for the courtesy lamps.
Personally, I think it would be far easier to just disconnect the battery than trying to unplug the clock, or pull fuses.
Install one of these on the negative post of your battery and isolate the whole car. These are made in two versions...the cheap $5 version and the better $20 dollar version. Dont cheap out. There is a difference.Put a tender on the battery. Same deal there. Look at The Battery Butler.
Not a bad idea.
Not a bad idea but i have an original reproduction on it and wanted to avoid chopping up a fairly new cable. Perhaps i can install an on/off switch on one of the wires under the dash.
This one is made in the USA and not a cheap China made one https://www.ebay.com/itm/40260867932...kAAOSwPCVX6n1I
