63 Olds Super 88. Fuel Tank Vent line
Gents, I need some opinions/suggestions...So here is the problem...I am cruising at nice speed say 45-55mph and when I floored the gass pedal the tranny downshifts to 2nd gear but the engine starts spotting, like loosing power or asking for gas. I parked the car and check the fuel pressure at idle, when cold is good 6-7psi when fully hot it drops to 3psi maybe 3.5psi, it is a new pump from Kanter, this one has no return line but my old one did, so i left the return hose open with a mess like filter at the tip to prevent dirt. Last note, the gas tank has a "vent hose" that runs from the top of the tank along the side of the filler neck, originally it had a "filter like" but it was old/rusted and I threw it away, could this missing filter be the cause of loosing fuel pressure? By the way my gas tank cap says " not vented" Can anyone school me on what does this means? Any help is greatly appreciated. Let me know if you need more info!
Angelo
Angelo
dfire25
June 28th, 2016 01:37 PM
bob p
March 18th, 2015 09:51 AM
