4 speed convention
4 speed convention
Help ! I'm converting a 72 supream rag top to a w 30 clone. I'm using n older muncy with the studs not bolts to hold on the shifter arms , Im not sure what mounting plate to use to put my hurst compation plus shifter in the rite place to match up with my console ???? If anyone can help me with an installation kit number or possibly has the whole shifter n linkages n shift lever ( I believe it has a double bend to clear the console ) for sale or swap please let me know. My cell is 570-444-5355. N I can give emale. Thank u all so much for reading.
Are you aware that the current Hurst Comp shifters are different from the original GM versions?
The shifter handle is #7169, and the shifter base is #3138.
The current Hurst Comp shifter will not fit a 70 console.
Do a search here, as there are many threads about this subject.
Big Mikey
March 27th, 2013 06:51 AM
