305 4bbl?
Old November 21st, 2014, 08:30 AM
Sammy70 455 Supreme
sammy's Avatar
305 4bbl?
I bought a 1984 Cutlass with a 305 4bbl. My question is did these motors come with the 4bbl from factory?....if they did not, I would assume it is a 350?...I guess the Vin would tell me....
Thanks,
Ted
sammy is offline
Old November 21st, 2014, 09:35 AM
FMB42's Avatar
Unless I'm mistaken, the 305s and 307s were available with 4bbl (Rochester Quadra-Jet ?) carbs. As for the VIN/Eng descriptor; unless I'm mistaken, the 8th digit should be an H if it's a 305.
FMB42 is offline
Old November 21st, 2014, 10:02 AM
Marx3's Avatar
My buddy has an ´84 Delta with the 307. It came with a 4 barrel Qjet.
All the Delta's and Caprice's from the 80's I have seen had a 4 barrel.
Marx3 is offline
Old November 21st, 2014, 04:04 PM
Sammy70 455 Supreme
sammy's Avatar
Thanks for the help, Car has the H in the Vin...
sammy is offline
Old November 21st, 2014, 07:00 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't believe Olds ever used the 305 which was a Chevy engine. It should be a 307.
redoldsman is online now
Old November 21st, 2014, 07:04 PM
Sammy70 455 Supreme
sammy's Avatar
Apparently Supremes destined for Canada got the 305.....
sammy is offline
Old November 22nd, 2014, 05:54 AM
starfire's Avatar
Yup, many, if not all, Canadian cars got the 305. Also the 305 was used in the H-special Starfires.
starfire is offline
Old November 22nd, 2014, 07:57 AM
The 305 "Type C" motor was also factory installed in the 1978-1980 Cutlii, as the only Olds motor offered in those cars was the 260 (with the exception of the 79 H/O and 80 442).
joe_padavano is offline
Old November 22nd, 2014, 08:10 AM
redoldsman's Avatar
I guess I am living proof that you are never too old to learn. This is the first discussion I remember concerning a 305 in and Olds. Thanks for the education guys.
Old November 22nd, 2014, 09:19 AM
Lansing built
1970cs's Avatar
Talking
1982 Canadian brochure.
1970cs is offline
droptop442
August 10th, 2009 07:52 AM
evilla
October 11th, 2008 04:10 PM
HAFROD
April 24th, 2008 03:12 AM
J-(Chicago)
July 31st, 2007 10:38 AM
mjregim
July 24th, 2006 12:43 PM
Quick Reply: 305 4bbl?
