2006 Suzuki Grand Vitara brake issues
My younger brother has a 2006 Suzuki Grand Vitara 4X4 that he drives to work. It needs front pads and rotors and he wants to replace the drums and shoes on the rear at the same time. We started on it last night and once it was on the lift, we tried to remove the rear drums with no luck. He used two 14mm bolts and ran them into the holes in the drums and hit it with a dead blow hammer with no luck. He also sprayed PB Blaster on the center of the drum. It will move out ward almost to the end of the wheel studs but is hung up on the brake shoes. Evidentially there is a ridge that they're hanging on and its pulling the shoes and hardware away from the backing plate. Unlike the old rear drums I'm used to working on, there is no removable rubber plug to use a brake tool on the star thingy to run the shoes inward, We thought maybe there is a problem with the parking brake and loosening it up might move the shoes back a bit but we can't get to the adjustment which is in the interior, under the rear of the console (per the factory service manual he has)! Has anyone here had experience with this type of vehicle rear brakes? If so, any help would be appreciated that will get us moving on this one.
OLE442
OLE442
BradyB
Brakes/Hydraulic Systems
20
September 25th, 2012 11:00 PM
yeahbuddy
24
December 12th, 2011 03:09 PM
