1970-72 A body Floor Mounted Speedo question
I'm sure that all the guys with bucket seat/console cars can answer this in a heartbeat. I saw a pic for a console shift speedo (on eBay) and noticed there was a gap / opening at the bottom where typically a column shift indicator would be displayed. (see green outline in pic). Anyway, it got me curious as I know that GM had some degree of predictability back in the day these were manufactured. Eg: the body wiring looms were basically all the same with pigtails for any options that may be ordered or installed in the cars. So, were all speedo clusters manufactured this way as a matter of just having a standard speedo pod?
I know how to alter my column shifter if need be and airbrush over the PRNDL. But would there be a different housing for a true column shift from the factory??
Time for the experts to weigh in...
Just checked my floor shift speedo. It's just as the one pictured. Your probably right about them making one speedo and then dressing them deferent per application.
If I had the one you pictured for sale I would hook my drill up to add 437 more miles and get it roll back to all zeros.
Hope that helps.
Hope that helps.
All the older cars can do the rollback, all the new cars don't work that way. They'll (new cars) register total mileage even if it's in reverse gear.
79MKII
August 16th, 2015 07:29 PM
oldspackrat
January 20th, 2014 05:14 PM
