1970-1972 Console lock bezel removal
I recently realized that my trunk/glove box key does not work with the console lock. I suppose I knew this 20+ years ago and simply didn't really care.
Well now I had some time and thought I would remove the bezel and swap the tumbler pins to match the key, but I have not been able to remove the bezel from the lock cylinder. Does anyone have tips or suggestions on how to remove the bezel?
Are you talking about removing the lock assembly from the console, or the lock cylinder from the housing? The latter requires the key to turn the cylinder far enough to disengage the retainer tabs. Without it there is some finesse required with tools to depress tumblers.
Joe, thanks for the info and pictures. Seeing them brought back memories of removing the cylinder on my ‘70 Supreme.
So any ideas on how to remove the cylinder without the correct key?
Apparently this is why I didn’t do anything with it 35 years ago.
On one I did recently, I actually had to make a key through trial and error to turn the lock cylinder. Once out, I was able to refile the tumblers to fit the new key. I'll suggest that removing the bezel might provide enough space to insert a piece of shim stock to hold the tumblers down. You can depress them one at a time in sequence with a probe or locksmith tool and then push the shim in to hold that one down while moving on to the next one. Note that this cylinder only uses five of the six tumblers that the door and trunk locks use. If that fails, you can find NOS cylinders on ebay, allowing you to drill the old one out enough to get the tumblers out and then turn the remaining shell. I prefer not to resort to that if possible. FYI, I have a tool that can re-roll the bezel if it's removed carefully.
Seriously, yeah, at a minimum it should show the tumbler differences, which will narrow down the possible number of key configurations to two or three. Pretty easy to cut test keys from that point.
