1966 442 - Correct body Trim Color
Old July 21st, 2019, 01:49 PM
forstatd's Avatar
Does anyone know the correct "grey" trim color on the 1966 442 or cutlass. I am looking to restore my trim and am looking for a rattle can with the right color or something very close that I can use. On some older posts, folks called it argent ... if so where can I purchase a spray can?... See the photo below for what I am talking about. Any assistance that you can provide would be appreciated!! ~Dave.
forstatd is offline
Old July 21st, 2019, 02:31 PM
66-3X2 442's Avatar
Dull Aluminum Krylon is good for that. It's hard to find and it might be too dull. The old paint was perfect but they changed the mixture. If you decide to use it,you might use a satin/semi flat clear over it to get the right sheen. One thing you need to be careful about,no paint will stick on the trim unless you use an epoxy primer first. The smaller stripe is black,not red.
66-3X2 442 is offline
Old July 21st, 2019, 05:02 PM
forstatd's Avatar
In my search for Krylon "dull Aluminum" with no luck so far... I noticed Valspar has a "dull aluminum" lacquer paint, $13 on Amazon... has anyone used this?
forstatd is offline
Old July 21st, 2019, 08:31 PM
66-3X2 442's Avatar
https://www.ebay.com/sch/i.html?_fro...paint&_sacat=0
Old July 23rd, 2019, 09:54 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I have had success with rattle can Chrome on several cars. Forget which brand, Dupli color or Krylon. Once it ages just a little bit it mimics the factory dull silver dead on(IMO). Argent is too dark IMO.
I used it on my 68 on the headlight buckets, the lower lip on the grill, trunk lip trim and SS2 center cap depressions. I'll try to remember to take some close-ups of the results(which by now are approaching 30 years old and still goin strong).
Don't rule out Eastwood. They have put a lot of time into various finish recreations
This should get you started:
https://www.eastwood.com/eastwood-detail-paint-kit.html
droldsmorland is offline
Cutlass Fan
Paint
October 27th, 2017 02:30 AM
Cina Sjöqvist
April 24th, 2017 11:15 AM
kelly bakies
Paint
May 29th, 2016 07:38 PM
kelly bakies
November 23rd, 2014 01:41 PM
L69 equipped
October 8th, 2013 09:27 AM
Quick Reply: 1966 442 - Correct body Trim Color
