1964 Dynamic 88
The lock bezel will not come off unless the lock cylinder is removed first .
Turn the bezel back in until it tightens up .
Get a paper clip and straighten it out .
Put the key in the ignition and turn it counterclockwise ( toward accessory position ) until it stops .
Insert the end of the paper clip into the small hole in the lock cylinder , and push .
Continue turning the key counterclockwise until it stops again .
The key with the lock cylinder attached can now be pulled out of the lock .
Then the bezel can be unscrewed completely .
Then the ignition switch can be removed out of the back side of the dash .
Joah_from_Alberta
September 9th, 2021 04:00 AM
