65 Jetstar rf turn signal problem
Old October 2nd, 2011, 10:59 PM
dennisspeaks's Avatar
After working on light problems for the last week, I am down the last wight that has issues. It's the right front turn signal light. When I have the lights on it is on working but when i put the turn signal on nothing happens. popped the bulb out and tried different bulbs, no change. The socket it self looks (i know looks can be deceiving) springs are strong and no rust or inside.
Amy ideas?
dennisspeaks is offline
Old October 3rd, 2011, 07:52 AM
Amy ideas?
Does the rear turn signal on the same side work? If so, the problem is likely a bad ground wire from the socket.
joe_padavano is offline
Old October 3rd, 2011, 08:06 AM
Yes Joe, the rear works. I will check the ground today. Thanks, have a great day!
costpenn
June 24th, 2015 10:38 PM
Mr Nick
May 27th, 2015 11:06 AM
luther
September 29th, 2007 10:41 PM
js_specials
August 18th, 2006 10:31 AM
Quick Reply: 65 Jetstar rf turn signal problem
