fuel gauge pegged F - whats next?
Old December 9th, 2016, 07:01 AM
  #41
Big Features's Avatar
The car is a 1968 442 HT. I replaced the gas tank, sending unit, soldered the ground with to the unit, I've tried several grounds, I even repaced the sending unit wire in the trunk. The gauge is stuck on "HOT" and does not move.
Big Features is offline
Old December 9th, 2016, 07:12 AM
  #42
You need to disconnect the sending unit wire at the back of the gauge and then ground the gauge terminal that you removed the wire from. If it does not go to E and you have 12v on the other gauge terminal your gauge is faulty. If it does go to E then your problem is an open wire from the gauge to the trunk.
oldcutlass is online now
JPMDaddy
January 31st, 2020 04:01 AM
Olds Dad
July 11th, 2014 04:56 AM
70OLDSCUTMC218
August 3rd, 2013 07:05 AM
BStone
August 2nd, 2012 07:56 AM
VikingBlue
August 12th, 2010 06:09 AM
Quick Reply: fuel gauge pegged F - whats next?
