92 Supreme Fuel Gauge Pegged "Full"
Old July 9th, 2014, 01:06 PM
Collector of Stray 55's
Olds Dad's Avatar
I know typically this is an "open" between the dash and the sender - anyone know of "typical" things that go wrong with this particular car based on your experience? I know I need to check the resistance, I know the float could be stuck, but what I'm looking for is "Oh yeah...the (BLAH BLAH BLAH) is ALWAYS the problem on the 92s..."
Olds Dad is offline
Old July 9th, 2014, 01:09 PM
If you disconnect the feed wire to the sender from the gauge and ground it, it will drive the gauge to read E with the key on. It's either a bad ground or sender.
oldcutlass is online now
Old July 9th, 2014, 10:01 PM
jaunty75's Avatar
Eric, this isn't answering his question. He already knows this. What he wants is someone to tell him, "Oh, all '92's do that. All you need to do is reattach the doohickey to the the thing-a-ma-bob, and the gauge will work."
jaunty75 is offline
Old July 10th, 2014, 04:47 AM
Olds Dad's Avatar
I appreciate all input - I'm going to "Go In" this weekend with my multimeter. I was just looking to start off in the right direction is all.
I suspect the answer to my question is not out there.
Just the joys of trying to resurrect a 22 year old car that's been sitting in a garage for 10 years
Olds Dad is offline
Old July 10th, 2014, 12:32 PM
jaunty75's Avatar
Never hurts to ask, though!
jaunty75 is offline
Old July 10th, 2014, 12:48 PM
Seriously, I've never used a meter, I just do as I explained above. Pretty simple to track down. Just take the wire off the doomefletchy and ground it with the key on. If the whatcha ma call it goes to E it's 99% of the time the doomefletchy thingy.
Happy Jaunty, I used the technical terms.
Old July 11th, 2014, 04:56 AM
Olds Dad's Avatar
NOW I understand
Olds Dad is offline
JPMDaddy
January 31st, 2020 04:01 AM
roscopdoggy
December 9th, 2016 07:12 AM
70OLDSCUTMC218
August 3rd, 2013 07:05 AM
ACID64
September 7th, 2011 11:16 AM
81 regency
April 21st, 2011 06:18 PM
Quick Reply: 92 Supreme Fuel Gauge Pegged "Full"
