erratic timing/hei
Old Mar 18, 2009 | 07:15 AM
BosMobile's Avatar
Unhappy erratic timing/hei
Hey guys ,72 cutlass/455/hei. All new internals[proform],recently installed msd-6a ,car runs great,tweaking timing and its moving 4-6 degrees.Im using standerd lite,is fire jumping inside cap ? mr. gasket advance wieghts? please help if your using msd-6a. maybe i shoud have spent that money elsewhere.thanx,BO
Old Mar 18, 2009 | 11:26 PM
88 coupe's Avatar
Junior Member
Originally Posted by BosMobile
........ maybe i shoud have spent that money elsewhere
Good thinking.
Norm
Old Mar 19, 2009 | 03:33 AM
yammiman's Avatar
I would check the cap, the coil, and the spark plug wires - beyond that, it would involve bad bushings in the distributor or bad timing chain - how many mile on the motor?
Old Mar 19, 2009 | 04:23 AM
You can always eleminate the MSD box by disconnecting it and running the car without it. If your problem goes away then you know that was the culprit.
Old Mar 19, 2009 | 07:35 AM
BosMobile's Avatar
no more msd!
thanx guys , everything was good before,so ill eliminate the box, maybe this lesson will save someone else some trouble and some money. by the way ,i saw no performance gain so for 250 i like to feel some diffrence.anybody want to buy a box?? thanx again.BO
Old Mar 19, 2009 | 07:39 PM
OLD SKL 69's Avatar
GM Enthusiast
Also check the distributor baseplate where the vacuum advance rod mounts into it. I have seen a few of these where the hole in the baseplate was much bigger than the rod on the advance unit. It should be a snug fit. That can cause some timing scatter as well.
Old Mar 23, 2009 | 09:22 AM
BosMobile's Avatar
thanx for replys, im pretty determined,ill figure it out,then post result.there are 2 many people running 6a box ,somebody has seen this before.im sure its somthing simple.thanx again,BO
Old Apr 9, 2009 | 07:44 AM
70_CS's Avatar
torque machine
im running msd's streetfire and that cost half the price and is just as good no problems yet.
Old Apr 9, 2009 | 10:47 AM
BosMobile's Avatar
Red face
THANKS,im in touch w/msd tech now,see how that goes,regardless ,ill post outcome here! oh i removed the box,put old module back in.ran fine.the spark is just so hot it trys to jump any where theres metal.ill get it,BOSMOBILE
joepenoso
Jun 4, 2014 01:56 PM
Vistabrat72
May 16, 2013 08:36 AM
56Holiday88
Nov 4, 2011 12:00 PM
midrange
Jun 30, 2011 09:53 PM
442scotty
May 13, 2009 05:42 PM
