wiring harness
Old August 30th, 2016, 05:32 PM
ankerclanker's Avatar
wiring harness
Ok guys, i'm pretty sure this has been asked before, but here goes anyhoo. I am looking for a complete plug and play wiring harness for my 65 f85, have looked at summit, opgi, jegs and m&h. who makes a harness that is a good replacement?
thanks
ted
ankerclanker is offline
Old August 31st, 2016, 06:37 AM
Have you tried American Auto Wire direct?
oldcutlass is online now
Old August 31st, 2016, 03:35 PM
franks71cutlass's Avatar
Ted, I highly recommend M&H!! I first researched what was out there, went to OPGI to see what harnesses they had for my 71 Cutlass Supreme! Found out they used M&H! So , went directly to them here in SoCal! Received a better price, not having a middleman! They build everything from GM specifications, right down to color matched wires and connections!
I replaced everything under hood, Engine Harness, A/C and Front End Harness! Plus they modified my engine Harness for HEI and Electric Choke! They have a small fee for those Modifications, I think less than $20 bucks each! It's over 3 years ago, so I would have to check my records! Everything plugged right in like factory, all the correct length of wire! No, slop what so ever!! Here's there info:
M&H Electrical Fabricators
13537 Alondra Blvd.
Santa Fe Springs, CA. 90670
Email sparky@wiringharness.com
Phone 562-926-9552 Ext. 209
Fax 562-926-9572
If you want the best factory correct replacement wiring for Most GM cars, theses are the guys! I wouldn't recommend anyone else! It's plug and Play, and can't tell from original, except there M&H Log on the end of the harness, in place of the GM code!
Going on 3 years not ever a issue with my replacement Harness!!
frank
PS, You can view some pictures in my gallery of the wiring if you like to see it installed!?
franks71cutlass is offline
Old August 31st, 2016, 06:48 PM
No I haven't, but I will now. thanks for the info
ted
68Tom
November 5th, 2008 05:30 AM
mugzilla
October 22nd, 2008 12:06 AM
Olds64
October 3rd, 2007 05:34 AM
elmo
September 23rd, 2007 02:49 PM
stuart
August 14th, 2004 02:24 PM
Quick Reply: wiring harness
