3V parasitic voltage loss
Old July 28th, 2016, 02:35 PM
Big Features's Avatar
Gang, I have a 1968 442 that is draining my battery. My fluke meter is telling me that I have a current draw of 3.012 amps on my battery. I pulled the fuses one by one with no change. Any ideas??
Big Features is offline
Old July 28th, 2016, 03:11 PM
Lansing built
1970cs's Avatar
Try unhooking the alternator. I assume doors closed and accessories were off?
Pat
1970cs is offline
Old July 28th, 2016, 03:24 PM
Pat
Yep goes away if I unplug either the alternator or voltage Reg. I had the alternator tested and it was good. Just replaced the VR as well. How can I be sure which is bad?
Old July 28th, 2016, 03:43 PM
You need to follow the current. Fortunately, 3A is a big enough current flow that it should be hard to miss (about 36W is being dissipated).
You have already tried disconnecting all of the fuses. Now go the opposite route:
Disconnect everything from the horn relay and check for current flow from the battery.
Now connect each single connector, one at a time, each one alone, and see which one causes the drain.
Now check the schematic and see what's on that line, and follow it through, disconnecting everything on it, until you find the source.
MDchanic is online now
Old July 28th, 2016, 05:59 PM
stellar's Avatar
Unplug volt reg plug. Test for voltage at disconected plug at #2 wire. If you have voltage there the alt is bad. The set up is (from left to right) F - field 2 stator R 3 battery 4 ign. With key in off position all reg plug wires except 3 should have no voltage. With key in run position 3 and 4 should have voltage. To repeat with regulator plug unpluged test #2 wire. There should be no voltage. If there is voltage a diode is leaking. The alt may test good for output even if the diode is leaking.
stellar is offline
Old July 28th, 2016, 10:48 PM
I had this issue back in the 90s with my car. It's fairly easy to check diode leakage.
Fun71 is offline
Old July 29th, 2016, 05:28 PM
Ok, so update: I replaced my voltage regulator and now the 3 amp draw is gone, but the GEN light is on. Only at idle, it goes away at cruise speed. BACK STORY: I replaced the points with PROTRONICS electronic ignition. After reassembling the car, I got the GEN warning light and replaced the voltage reg and alternator.
Old July 29th, 2016, 05:39 PM
Old July 29th, 2016, 05:40 PM
Testing the Reg connector, checks out good
Old July 29th, 2016, 08:54 PM
That is exactly the symptoms of a leaky diode.
Fun71 is offline
Old July 31st, 2016, 06:31 AM
Looks like the Voltage Reg was bad. It was brand new too, just went poof I guess. The car runs perfect now and no loss or idiot lights. Thanks all!
Old July 31st, 2016, 06:50 AM
Bad Out Of The Box.
Courtesy of the Great People's Republic and all-around good guys of the Pacific.
Old July 31st, 2016, 06:58 AM
jpc647's Avatar
When I went to buy a new voltage regulator, I found two bad ones out of the box. One from advanced, and one from Autozone. One did exactly what yours did, it kept my gen light on. The second one hummed. I know that sounds crazy, but I could hear it hum at low speeds/idle. I ended up buying one from Napa. Only external difference was the napa one was bolted on, where the original was riveted.
jpc647 is offline
Old July 31st, 2016, 07:01 AM
Notable Bad Out Of The Bow experiences I've had included SEVERAL condensers and two HEI modules.
If there is an ability to test, always test new parts before leaving the auto parts store.
Old July 31st, 2016, 07:13 AM
Bad electrical parts out of the box is not a new issue, I've gotten them since the 70's and not just the chinesium ones. Its frustrating.
oldcutlass is online now
71CutlassS455
November 14th, 2015 05:54 AM
delta_88_germany
February 22nd, 2014 01:48 PM
Dru
February 7th, 2011 04:08 PM
martine
January 3rd, 2004 11:29 AM
martine
August 16th, 2003 07:49 AM
Quick Reply: 3V parasitic voltage loss
