wire location Q?
Old July 18th, 2010, 12:24 PM
hamm36's Avatar
wire location Q?
Note in photo:
What is the yellow lines around?
What is the wire the white lines are around?
Should they go together?
Note the contact arrangement. I can change out the connector, but I want to make sure that is where it goes. I did redo a lot of the wiring for this car and I made a mirror image of the original, but maybe I missed something, it was over a yr ago.
72 Cutlass, TY
hamm36 is offline
Old July 18th, 2010, 08:22 PM
svnt442's Avatar
The switch is the neutral safety/reverse light switch. Not sure about the wires....let me check something....
svnt442 is offline
Old July 18th, 2010, 08:23 PM
svnt442's Avatar
svnt442 is offline
Old July 18th, 2010, 08:33 PM
hamm36's Avatar
Trans Switch ??
Randy, am I reading that right?
Sorry, I can not find my wiring diagram. I put it up so it would not get messed up, now I can not find it. And I have looked several times around here over the past year.
hamm36 is offline
Old July 18th, 2010, 09:13 PM
svnt442's Avatar
That could be. If you don't have a TH400 then don't worry about it.
svnt442 is offline
Old July 19th, 2010, 05:43 AM
Lady72nRob71's Avatar
I believe the white boxed plug is for the TH400 kickdown switch that would be mounted at the gas pedal. For TH350 trannies, it just hangs there.
What tranny do you have behind that 455 of yours??
The yellow boxed section of the neutral switch is for the seat belt warning system. Those two contacts close when in Drive.
The schematic above does not show it since it is for a pre 1972 model.
Lady72nRob71 is offline
Old July 19th, 2010, 12:52 PM
hamm36's Avatar
I got the big honcho 350 trans.
Thanks for the help. I will tie it back out of view.
hamm36 is offline
wisniows
February 2nd, 2014 10:40 AM
pbarney
February 10th, 2013 12:59 PM
superstingray77
June 27th, 2011 06:13 AM
Joel
April 12th, 2011 02:58 AM
68cutlassdriver
March 6th, 2011 11:53 AM
Quick Reply: wire location Q?
