Windshield Wiper Motor
I decided awhile back to remove my recessed park wiper motor (part 4918070) from my 70 Supreme because the pump was not working and it was filthy. So I bought a pump and cleaned it. The trouble began when I was unsure how to hook the wires back up. I guess I crossed them up and the motor went up in a puff of smoke and now even the wiper arm motor does not function. Bought used motors no change. The fuse looks ok and I do measure current at the wires. The Olds factory manual shows and describes in good detail how the lower set of wires are installed but doesnt show how the top set of two wires (Blue / Yellow wires should be installed. Can someone check their motor to tell how theirs is setup? Not sure how to fix this and need help? Thanks in advance,
