Old School speaker box
Old May 28th, 2009, 07:36 AM
Wireman134's Avatar
Haven't been able to do much to the car this year because of the money situation, so I decided if I'm going to cruise around here and there I need some tunes. Since the factory AM radio limits my listening enjoyment, I went to work on a solution. I wanted to keep the factory radio wired to the front speaker just in case I wanted to flash back to the 70's. I had some sound system parts laying around, a vintage pare of new Kraco Slimline 5" dual cone speakers I bought back in the mid 80's to install in my 72's doors or kicks and a recently acquired Pioneer 4X45watt Super Tuner III CD head unit. I just needed rear speakers for the tray and got some Sony Xplod 6X9 3 ways. I installed the 5" Kraco's in the kicks with the head unit located in the dash glove box. Sound was real good but I felt the Kraco 15 watt max needed a little help so I thought of designing a box to straddle the console under the dash, out of the way angling speakers toward the front occupants. Mocked up the model out of cardboard after taking some measurements. After 8 or so hours, a little scrap plywood, with another new vintage set of Kraco Slimline speakers from a E-bay seller, and viola, a retro speaker install from back in the day.
The box is temp wedged in place with some high density foam rubber and foam protecting the console contact surfaces. Took a little fitting to get it right then stained it walnut. What do you guys think.
Wireman134 is offline
brandon 455
November 7th, 2013 06:47 PM
Rowdies
February 10th, 2012 07:57 PM
71rocket
August 2nd, 2009 04:28 AM
Wireman134
May 31st, 2009 04:34 PM
<ohio2atl>
January 28th, 2005 11:38 AM
Quick Reply: Old School speaker box
