Oil and water temp sending unit wires
Can I run two new wires for thes sending units as they are missing and if so where and what color do they connect too ? As I’m installing Ralley pack gauges but missing the wires under the hood ? Thanks
Series 56 male terminals. You can get them at Napa pretty cheap.
Take a closer look at the firewall connector. Unless someone took the time to remove the connector body and remove the wires from the housing, I bet they are there. Unless the cut them flush with the housing?
Thanks Joe,
as soon as I posted this I was tugging on a blue and green wire and
they both came out of the firewall capped off and ready to go right where I left them about 10 years ago lol 🤣😂🤣 thanks for the quick response !
texasred
July 31st, 2007 10:18 AM
<mr.stew@netzero.net>
October 18th, 2004 11:20 AM
