Instrument/Speedometer lights
Old April 18th, 2018, 03:43 PM
foulpalamont's Avatar
Hey all-Seems like a simple enough thing, but I've been slowly getting all of the electrical together on my 1964 Jetstar 1. Everything is almost there. However, I have no lights in my instrument panel. I can't see the speedometer at night, etc. The lights for the flashers and the high beam indicator all work. Is there an easy way to check just the bulbs in the instrument panel without tearing the whole thing out? Or is this indicative of something bigger? Thanks. Brian
foulpalamont is offline
Old April 18th, 2018, 06:41 PM
Have you checked the instrument lamp dimmer and the fuse?
oldcutlass is online now
Old April 19th, 2018, 07:03 AM
Hey OldCutlass. As always, thanks for helping! Yes, I checked the rheostat and I checked the fuse. The fuse is good, but the lights do not fade up if I turn the light switch one way or the other. I looked under the dash the best I could this morning and found evidence of an electrical issue though. However, I'm not sure what I'm looking at. This is directly above where the steering column lies and seems near to where the instrument cluster is. Can you see what this little block is that these two connectors are wired (burned up) into?
Old April 19th, 2018, 08:38 AM
I can't tell what the block is. Can you trace it further? Tan may be the heater switch, the red may be the clock? Lighting wires are gray.
Old April 19th, 2018, 09:29 AM
Yes, this was part of the heating unit. I retired them and cleaned that up a bit, but the lights in the instrument panel, nor the clock are working still.
Old April 19th, 2018, 09:37 AM
With a test light or volt meter, check both sides of the instrument light fuse and see if there is 12v when the light switch is pulled out. if there is 12v on one side and not the other, pull the fuse, clean the contacts and try again.
Old April 19th, 2018, 10:55 AM
Something I should have tested in the first place I guess. There's absolutely no juice coming to that fuse...or to the under hood fuse. Just so I'm clear, I'm looking at the Instrument Bundle fuse, correct? What are the panel lights? From the diagram, things look a little mixed in. Could there be something in the engine compartment that I should be checking? Because I'm having a hell of a time seeing the backside of the fuse block to check that connection...
Let me clarify. The Panel Lights and Under Hood Lights fuses are getting no juice. The Instrument Bundle is getting full juice.
Old April 19th, 2018, 11:03 AM
RandyS's Avatar
All of your instrument panel, (dash lights) run from the fuse marked 'Panel'. These are the ones that come on when you turn your headlights on.
RandyS is offline
Old April 19th, 2018, 12:06 PM
I meant panel light fuse. There is only voltage at the panel light fuse if the headlights are turned on.
Old April 19th, 2018, 12:30 PM
Okay, gotcha. Thank you. This is what I'm finding. No juice at all when the lights are on or off to the Panel Lights fuse. I've even gotten a mirror in there and tested the back of the fuse block connections and there was no juice back there either. Does this sound like the Headlight switch where the rheostat is? The rheostat is pretty squeaky when I turn it.
Old April 19th, 2018, 12:37 PM
The gray/black wire from the light switch is what powers that fuse. If you see no voltage there then your issue is at the light switch or that wire. Try turning the rheostat back and forth as they do get dirty, if that does not work replace the switch.
You can also jumper 12v to the panel fuse to make sure the lights light.
Old April 19th, 2018, 02:10 PM
Make sure your jumper wire has a fuse also, if there is a wiring issue no fuse to protect things might let the smoke out of the wires!
matt69olds is offline
Old April 19th, 2018, 02:15 PM
So I jumped the Panel Light fuse and voila! I have instrument lights. However, it looks like only half of the speedometer is lit, but whatever. I'll fight that another day. However, I reached up above the headlamp switch, pushed the button on top and tried with all my might to remove the headlight pull. I cannot figure this out and I'm scared to jam it too hard so I don't break it and have to saw off the pull. Any ideas? Is there a technique I'm missing?
Old April 19th, 2018, 02:36 PM
Nevermind! There is a technique and I figured it out and am holding my rusty busted switch. I'm thinking I should just replace this and not try to restore it. Thoughts?
Old April 19th, 2018, 02:47 PM
RandyS's Avatar
Buy a new one, they are not very expensive.
RandyS is offline
Old April 19th, 2018, 02:55 PM
You may have to clean the inside of the plug, you have some corroded terminals there. Ohm across the 2 outer terminals of the rheostat should be a fixed resistance. Then ohm across the center to each outer and the resistance should vary when turning the headlight **** from stop to stop. You may just need to clean it up.
Old April 19th, 2018, 02:58 PM
I bought this one. I figured it'd be nice to have a clean start.
Amazon Amazon
Thanks for all your help gents!
Old April 19th, 2018, 03:17 PM
They don't look the same, there is an extra terminal above the 3 rheostat termanials. Is there a slot in your connector for it?
Old April 19th, 2018, 04:01 PM
Woah! Good eye! I cannot find one that doesn't have that extra connector. I wonder if I could lose that connector and it would still work. Of course I'm not sure what that connector does, but it looks like the one I have is pretty much the same as the new one I wanted to buy (the old one even has a space for this extra connector). Thoughts?
Old April 19th, 2018, 05:14 PM
RandyS's Avatar
Does the terminal interfere with the plug attaching?
RandyS is offline
Old April 19th, 2018, 06:38 PM
I’m betting not, but I haven’t given it a good look yet. Will let you know.
Old April 19th, 2018, 07:07 PM
Try it, maybe it will work. Like I said above, you might try cleaning the old one also.
Old April 23rd, 2018, 11:05 AM
Alright, gents, just to prove I'm the cheapest person here, I give you evidence of what I've done to retrofit the newer switch with a cut off section of the old switch. The newer switch's threaded part, that the bezel screws into was too small, so I ground out that part on the new one, cut off the properly sized one on the old one and JB Welded them together. Also, on the plug, there is a slot for the blade that the old one didn't have, but it goes no where, so I left it alone. Everything's working great. The left side of the speedometer is brighter than the right side. Are there two bulbs? Maybe one's out?
Old April 23rd, 2018, 12:33 PM
Good work, glad its fixed. If its dim on one side you may have a bulb/s out.
Old April 23rd, 2018, 03:18 PM
Thanks Eric. Are those bulbs directly in the instrument cluster? Are they easy to pull?
Old April 23rd, 2018, 03:50 PM
Not sure on your car.
deltaroads
October 26th, 2015 04:08 PM
arod40
June 15th, 2013 11:16 PM
68RocketAction
June 7th, 2013 09:21 PM
Dshelvy
March 19th, 2012 08:12 PM
dhoff
May 28th, 2010 05:19 AM
Quick Reply: Instrument/Speedometer lights
