How to test fuel tank sending unit?
Old September 5th, 2016, 07:00 AM
Chris
Oldssupreme's Avatar
I am not very well-versed in electrical matters. Can anyone explain how to test a fuel tank sending unit from my 72 cutlass so I can determine if it works before I install it in the tank? I do have a multi-meter, just not exactly sure how to go about testing it. Thanks!
Oldssupreme is offline
Old September 5th, 2016, 09:54 AM
Search and ye shall find...
https://classicoldsmobile.com/forums...tml#post912479
MDchanic is offline
Old September 5th, 2016, 09:56 AM
Lansing built
1970cs's Avatar
Most sending units have a center post and possible ground tab.
Hook your meter to the center post and tab, if no ground tab then clamp to the mounting flange. Set your meter to low range ohms and move the arm up and down and you should see a varied resistance through out the range of travel except may the last area of empty or down.
Pat
1970cs is offline
Old September 5th, 2016, 12:49 PM
Chris
You guys are awesome. Thank you. I will try that!
Chris
Old September 5th, 2016, 06:04 PM
GM sending units are 0-90 ohms. The lower the resistance, the lower the gauge reads if the wire between the tank and gauge is open, it will read beyond full. If the wire is grounded, it will read empty.
matt69olds is offline
Old July 27th, 2017, 02:43 PM
Chris
Hi guys. Does anyone have a photograph showing exactly where to hook up the multimeter to the fuel tank sending unit out of the car to test it? Thanks!
Old July 27th, 2017, 02:46 PM
There's a little brass snap connector and ground.
Not too many ways to do it wrong.
MDchanic is offline
Old July 27th, 2017, 03:07 PM
It should range from 0-90 ohms.
oldcutlass is offline
Old July 27th, 2017, 03:57 PM
Connect the meter positive to the brass post above the yellow insulator and the meter ground to the ring terminal on the wire or any part of the metal flange.
Fun71 is offline
Old July 27th, 2017, 04:54 PM
Chris
Ok! Thanks guys!!!
Old July 27th, 2017, 06:58 PM
Or vice-versa. Doesn't matter.
MDchanic is offline
dallasite21
October 1st, 2021 05:21 PM
68RocketAction
December 18th, 2014 11:19 AM
pfergy600
October 4th, 2014 05:29 PM
1carsick
October 17th, 2012 09:10 AM
IB Adrian
September 12th, 2009 12:43 PM
Quick Reply: How to test fuel tank sending unit?
