heater blower resistor
Old April 5th, 2017, 08:37 PM
Rattlecan's Avatar
I'm troubleshooting a problem with my heater blower. Specifically, it's no longer blowing!
I've got the 12v+ to the switch, then a wire to the blower on a two-conductor plug on the blower switch. I also have a three-conductor plug on the switch.
Looking at the wiring diagram these three should go to a resistor.
Where would I find this, and what does it look like?
Does the switch need a ground, or anything else?
My car is a '69 442 Vert w/AC.
Thanks,
Rattlecan
Rattlecan is offline
Old April 5th, 2017, 09:27 PM
Have you checked your Chassis Service Manual?
Pages 1C-42 and 1C-44.
MDchanic is offline
Old April 6th, 2017, 08:30 AM
Olds Fever
CRUZN 66's Avatar
I just happen to have a couple 69 Chassis Manuals for sale...
CRUZN 66 is offline
Old April 6th, 2017, 09:19 AM
Yellowstatue's Avatar
There are three switches on the dash control to put power on the blower motor. The 'speed switch', the 'air on' switch and the 'max A/C' switch. When 12v leaves the speed switch it goes to the resistor, from there it goes to the high speed relay near the brake booster, then it goes back directly to the blower motor. I had trouble with the max switch not closing. Once I squeezed the switch to get the contacts to touch, it was good to go but it took a couple of weeks to figure out this problem. This on Muskrats '68 W/ A/C.
Yellowstatue is offline
dahaze
February 9th, 2017 05:30 PM
Hoosierboy1997
September 30th, 2016 01:38 PM
W-27
July 23rd, 2015 07:55 AM
redvettemike
September 6th, 2010 07:06 PM
jeffreyalman
May 20th, 2009 01:13 AM
Quick Reply: heater blower resistor
