Dash Bulbs
You can buy LED bulbs that are not polarized. The real problem is that the factory alternator system requires the resistance of the filament in the incandescent bulb to trigger the voltage regulator.
Related question. Mine is a 1970 cutlass and tge lens for the high beam indicator is gone. Can you get a replacement, can you use some type of cellophane or plastic or would it just be easier to get a colored bulb?
w30brad
February 8th, 2020 02:41 AM
