Convertible Top - 30A Breaker Wiring
Old December 19th, 2013, 08:20 AM
Mike H.'s Avatar
I have a '68 Cutlass with a convertible top and no other power accessories. The 30A breaker is mounted on the driver's side firewall. The wiring is somewhat cut up. I have one red w/ black stripe wire and one plain black wire that looks like they were hooked up to it.
Can anyone with a convertible top verify this or take of pic of what they have? Yes, I looked at the service manual wiring diagram...it didn't help.
Mike H. is offline
Old December 19th, 2013, 10:07 AM
Texas69's Avatar
My 69 has one red wire from breaker to horn relay under the hood and an orange wire to the top switch inside the car. Yours should be similar. See page 12-134 in the 69 assembly manual
Texas69 is offline
Old December 19th, 2013, 10:31 AM
Mike H.'s Avatar
Texas69,
Thanks for the quick and detailed reply. Apparently, there has been more re-wiring on my '68 than I thought. I have the service manual. Apparently I need to get the assembly manual as well.
Thanks again, Mike
Mike H. is offline
Old December 19th, 2013, 10:56 AM
brandon reynolds's Avatar
mike sign up to wild about cars and you can go on there and look at assembly manuals for free. brandon
brandon reynolds is offline
Old December 19th, 2013, 12:53 PM
Mike H.'s Avatar
Good advice. Thanks, Mike
Mike H. is offline
Old December 19th, 2013, 03:05 PM
allyolds68's Avatar
Originally Posted by Mike H.
Texas69,
Thanks again, Mike
The wiring diagram is in the Service Manual, not the Factory Assembly Manual for 68. The assembly manual won't tell you much of anything about the convertible top wiring other than the 30 amp breaker location, switch location, and wire routing. It doesn't have much for color identification either. It's section/page 12-115 and 12-131 of the 68 manual
allyolds68 is offline
Old December 20th, 2013, 10:35 AM
Mike H.'s Avatar
allyolds68,
I have the wiring diagram from the service manual. I did not find the red w/black stripe wire in it anywhere. I will start to track the wires this weekend. Thanks, Mike
Mike H. is offline
Mattia-SS
March 23rd, 2012 12:30 PM
dhartley72
October 18th, 2010 12:09 PM
LadderSponge
September 29th, 2010 03:23 PM
SteveL442
August 5th, 2010 09:23 AM
J-(Chicago)
July 20th, 2007 08:25 PM
Quick Reply: Convertible Top - 30A Breaker Wiring
