'63 F-85 relay on passenger fenderwell
What is the relay on the passenger fenderwell closer to the firewall than the bumper? I know the horn relay/tie point. This one is the one closer to the firewall. Thinking it needs replaced. It sure is making a hell of a racket.
Thanks in advance for any help identifying this guy.
How many and what color wires go to it?
If there are four wires, white, red, green and blue, it's the voltage regulator.
If it's smaller with three wires, red, purple and brown, it's the generator warning light relay. Olds used that relay only for a couple years and I've never owned a car with it, so I'm useless as far as troubleshooting it.
I was a little groggy when I first posted this. Of course a photo is required
I know the one that says NAPA on it is the voltage regulator. The car currently has an externally regulated SI style alternator.
Wondering what the relay is on the fenderwell.
Thank you for the replies.
All 63's have alternators, but that is what the factory CSM calls it.
Far as I know only 62 and 63 cars had this warning light relay and I think it was part of the generator to alternator changeover, as the relay is not mentioned or shown in the Sept 61 printing of the 62 CSM. The May 1962 Service Guild goes into detail on Delcotron service and covers the warning light relay.
!! You mentioned an SI alternator. If the alternator has been rebuilt or replaced, it's possible this alternator has the warning lamp circuitry INSIDE and may be what's making the GWL relay holler.
Anyone have a simple how-to on converting to a SI that would eliminate this relay?
Don't waste your time with a one-wire alternator, use a factory-style three wire setup. Note that the diagram shows the wire from the no. 2 terminal going directly to the threaded BATT post on the alternator, This will work (and I did it because it was easy for now) but in reality that wire is the voltage sense feedback wire that should go all the way back to the junction block so you account for all voltage drops in the system. I'll correct that when I build my new wire harness, but as I said, it works for now.
There's a catch to picking up the sense voltage in the dash to compensate for voltage drop in the harness - you can overcharge your battery. I always set the sense voltage at the output of the alternator, which if the wiring is correctly sized and in good repair will be battery voltage. I will be updating the alternator to a CS130 style alternator when I get to that point.
The thing I'm wondering is what that warning light relay circuit looks like. Hmm. The generator warning light relay was making a lot of noise, so I disconnected it for now. I'm still charging so, I'm guessing it is only for the warning light.
Joe, does your warning light function correctly with the 10SI? If so, which wire is the warning light wire?
Thanks!
Steven
Thanks!
Steven
Yes. In fact, the resistance of the warning light is needed by 10SI to properly turn the alternator on at idle speeds (that's why the one-wire alternators typically don't charge below 1,000-1,500 RPM). There is a brown wire in the harness that runs to the light. Simply connect it to the no. 1 terminal on the 10SI, as shown in the diagram. Note that my 62 F-85 did not use a warning light relay, but I can't see why that matters in your case. The warning light simply has +12V on one side and is connected to the regulator (internal or external) on the other side. The regulator grounds this terminal when the alternator is not charging, causing the light to illuminate. When the alternator is charging, you get +12V on the no. 1 terminal, so there is equal voltage on both sides of the lamp and thus the lamp does not light.
F-85 4-4-2
September 29th, 2014 03:29 PM
