1955 98 wiring help
Old January 22nd, 2015, 12:55 PM
jess1955's Avatar
1955 98 wiring help
Hi All,
I have a 1955 Oldsmobile 98. I recently switched out the 324 for a 350 Chevy. I need to hook up the temp gauge and i am lost! I have three wires coming out of the gauge. Need to figure out what goes where....
Can anyone help?
Thanks,
Jesse
jess1955 is offline
Old January 22nd, 2015, 01:48 PM
I believe, 1 wire is B+, the other is lighting, and the 3rd goes to the sending unit. I would think 2 of the 3 would already be wired unless you/ someone removed the harness.
oldcutlass is offline
Old January 22nd, 2015, 03:36 PM
jess1955's Avatar
Thank you for the reply. I have been messing with this thing all afternoon. I figured a few things out.... sort of.
The green wire is the fuel gauge. When I hook that up to power the fuel gauge gets a reading.... probably the first time in 20 years. Im not sure its accurate but it jumps to full. Im going to drive the car a bit and see if I get a different read on the gauge after time. Maybe the reason the fuel gauge doesnt work is that this wire supplies the power it needs.
That leaves two wires. I figured out that when I put direct power to the black wire the car turns over.... strange. Im guessing this wire goes to the ignition.
The yellow wire must go to the sending unit. That said I still cant get it to work.
jess1955 is offline
Old January 22nd, 2015, 04:18 PM
I changed your title and hopefully one of the guys with a 50's car can point you in the right direction. You really need a wiring diagram.
Old January 23rd, 2015, 07:34 PM
Ozzie's Avatar
To the best of my knowledge all the electrically operated gauges on the 1955 have two wires each:
fuel: a yellow 18 ga. which goes to B+ on the switch
a gray 18 ga. which goes to the gas tank unit
temperature: a yellow 18 ga. which goes to B+ on the switch
a green 18 ga. which goes to the engine unit
ammeter: one orange (to junction block) and one red (to a splice with other reds)
There are some grays (18 ga.) on the instrument panel for lighting purposes.
Ozzie is offline
Old January 25th, 2015, 12:24 PM
jess1955's Avatar
Hi Ozzie,
Hope I can ask a stupid question.... what do you mean by B+ on the switch. Where would this connection be?
Thanks,
Jesse
jess1955 is offline
Old January 25th, 2015, 04:11 PM
B+ is the switched 12v source that is only on when the key is on.
Old January 25th, 2015, 05:17 PM
Ozzie's Avatar
Originally Posted by jess1955
Hi Ozzie,
Thanks,
Jesse
Eric has provided your answer.
I am unsure if the Chevy temperature unit in the engine will be compatible with the Olds gauge. Either verify this or use the one from the Olds engine.
Ozzie is offline
Old January 26th, 2015, 07:40 AM
The sending unit has to be compatible to the gauge. If originality is not an issue, I would go with an inexpensive 3 gauge mechanical setup mounted under dash.
GTC
March 19th, 2013 09:57 PM
oldzy
September 10th, 2009 05:23 AM
sanemb
May 30th, 2008 07:48 AM
dendav
March 30th, 2008 06:41 PM
TIREGUY
December 16th, 2006 04:10 PM
Quick Reply: 1955 98 wiring help
