1963 Super 88 Back Window Trim Installation
Old March 29th, 2017, 09:21 PM
psax42's Avatar
I can't figure out how to get my chrome on. Any advice appreciated
psax42 is offline
Old March 30th, 2017, 12:02 AM
Junkman's Avatar
It looks like it goes under the side pieces, so I have to believe that at least one of the side pieces has to be removed first to get the bottom piece installed. Then you put the side piece on. Don't know how the side piece is retained to the body, but start by trying to release all the windshield clips, and see if it comes loose. On some GM cars of that era, I have seen where they used a clip that had a stud on it, that held the molding in place with a nut on the inside of the car on the stud. If that is the case, you might have to disassemble some of the coverings on the inside at the side of the rear window. If it has a stud, make sure to reseal it when you reinstall the side molding, so you don't have any water leaks.
Junkman is offline
Old April 7th, 2017, 07:22 AM
psax42's Avatar
No bolts on the back of these. I think they snap in but there is a trick to it. Can't figure it out.
psax42 is offline
Old April 7th, 2017, 09:05 AM
Phantom Phixer
Charlie Jones's Avatar
I didn't know how to do this either . Until i got one of these ;
http://www.ebay.com/itm/1963-OLDSMOB...RYVwiY&vxp=mtr
It covers both body and chassis , and it's a "must have " if you own one of these cars .
Charlie Jones is offline
Old April 10th, 2017, 05:17 AM
5998DownUnder's Avatar
Mine has the bolts through the bodywork, but these look familiar to something I had on my 59, somewhere, can't remember exactly.
Maybe slide strip along or place over over the two 'tyne' fingers, then when in position snap bottom with a firm push down. Should snap into place.
5998DownUnder is offline
Old April 15th, 2017, 07:12 AM
psax42's Avatar
trying that but they are not snapping. My mechanic thought there might be a special tool for this.
psax42 is offline
Old April 15th, 2017, 01:03 PM
I have a scan from the book for you.
You will have to flip it I could not scan it the other way because of the spine of the book and the scanner lid.
There are a few different styles specified, not sure which is your though.
Hope this helps.
File Type: pdf
Old April 15th, 2017, 01:06 PM
Out of curiosity, what is the style of your Olds?
"11", "19" or "37"?
Old April 15th, 2017, 01:14 PM
Bottom left of page point 3.
Mentions 'pry disengage prongs' installation reverse removal.
I'd try starting from the side and sliding chrome strip along bottom of window collecting each clip.
Old April 15th, 2017, 01:19 PM
psax42's Avatar
As I read this I think these are the inside moldings. I am looking to replace the outside (lower) molding. Thanks for the effort
psax42 is offline
Old April 15th, 2017, 02:58 PM
They speak of roof drip scalp mouldings and reveal mouldings which are external.
Mrgadget
February 6th, 2017 11:50 AM
Don R.
April 18th, 2015 01:48 PM
Rocket331
September 16th, 2012 08:15 AM
Atdog
June 30th, 2010 07:43 PM
hamm36
Body work
January 4th, 2010 08:42 PM
Quick Reply: 1963 Super 88 Back Window Trim Installation
