15 inch wheels for 1958 Super
Old June 29th, 2016, 10:47 AM
holidaysedan's Avatar
What years of stock 15" steel GM wheels will fit on a '58 Super 88?
holidaysedan is offline
Old June 30th, 2016, 05:39 AM
Define "fit". If all you care about is the bolt pattern, then any 15" wheel with the 5x5" bolt circle fits. That covers every Olds full size (except the Jetstar 88) through 1976 and the RWD full size cars with HD brakes through 1992.
joe_padavano is offline
Old July 5th, 2016, 09:01 AM
navvet's Avatar
You'll be amazed at the difference in ride going to 15 inch
navvet is offline
Old September 17th, 2016, 03:43 PM
How about GM pickups of the 8os? Still around in yards. Also there's a 79 Electra with 15s in the yard nearby?
I want to use 225/75r15 tires.
Old September 17th, 2016, 05:55 PM
The Electra should have the 5x5 bolt circle, as do SOME of the half-ton pickups.
Old September 19th, 2016, 05:34 AM
Thanks Joe!
Old September 21st, 2016, 11:00 PM
az2bc's Avatar
Printing up one of the available online bolt pattern guides is helpful when searching wrecking yards.
Scratch your hub on it. Our wheels are hub centric, and regardless of matching lug pattern, the hub should fit, too.
I ended up with a set 15" steel in black with tires and a full set 15" chrome steel from a few RWD Cadillacs.
az2bc is offline
dz442
September 6th, 2019 03:55 PM
timothypaul
April 17th, 2013 08:35 AM
shreddin70
May 3rd, 2010 03:10 PM
400mphpc
Wheels and Tires
January 29th, 2010 12:08 PM
Bobac455
November 30th, 2009 03:05 PM
Quick Reply: 15 inch wheels for 1958 Super
