1984 transmission oil change
Old September 19th, 2016, 01:05 PM
Stephen0523's Avatar
Hi all. I'm going to change the transmission oil in my 1984 Delta 88 with the 307 engine. It has the 16 bolts on the pan and I have purchased a new filter gasket and O-ring and oil of course.
Does anyone have any tips for advice before I proceed?
Stephen0523 is offline
Old September 19th, 2016, 01:30 PM
blakes7's Avatar
Make sure you have a large enough drain pan.
blakes7 is offline
Old September 19th, 2016, 01:36 PM
For sure LOL!
How many litres do you think are in there?
Old September 19th, 2016, 01:38 PM
Get the biggest drain pan you can, and a bag of speedi-dri.
joe_padavano is offline
Old September 19th, 2016, 01:39 PM
Lots of Speed Dri and a tarp on hand.
Just searching to see how many litres it holds?
Old September 19th, 2016, 06:30 PM
4 Barrels of Laughs
quaddriver's Avatar
Location: I moved to pittsburgh so I can be near Primantis
total drain plus converter, just shy of 12qts, or close to 12.5L
BUT, without a total drain and just a pan drop, perhaps 4, why they say 'big' pan is to catch ALL the drip area.
quaddriver is offline
Old September 20th, 2016, 01:40 AM
Ozzie's Avatar
The LARGE developing trays for prints that were used in chemical darkrooms make excellent drain pans for transmissions without drain plugs. Just loosen all bolts a bit. Then break the pan loose if it doesn't release itself. If you think that you may have to do the job again some day, you can add a drain plug. Just get a NPT bung and braze or weld it to the lowest part of the pan. Drill a hole in the pan and you are ready for a clean drain next time. Be sure to also drain the torque converter or you are only doing part of the job. Use the correct fluid.
Ozzie is offline
Old September 20th, 2016, 12:33 PM
jaunty75's Avatar
It's an American car. It doesn't hold liters. It holds quarts.
jaunty75 is offline
Old September 21st, 2016, 06:18 AM
Would anyone use gasket sealer?
Old September 21st, 2016, 06:39 AM
Professur's Avatar
No need with a new clean gasket.
I use one of those Under the Bed containers. Stupid big, but shallow. Clap the lid back on when you're pulling it out and you've no worries about slopping. Draining it into the empty bottles for recycling is a bit challenging, but a siphon tube gets the job done.
Professur is offline
Old September 21st, 2016, 11:30 AM
Hi all. Thanks for all your guidance!
Perfect job with minimal spillage!
Old September 21st, 2016, 02:06 PM
Professur's Avatar
You wanna look at pic #1 and say that again?
Old September 21st, 2016, 04:44 PM
Hi Professur, not sure what you mean!
Old September 22nd, 2016, 03:12 AM
4 Barrels of Laughs
quaddriver's Avatar
back in the day, hydro started stamping the pans with the word........
Old September 22nd, 2016, 04:48 AM
I checked the oil this morning and the level seems a bit high. What would be the best way to remove some fluid? I have one of those Little pumps that go into a drill and Maybe going through the dip stick?
Perry615
April 16th, 2013 05:55 PM
dre
Drivetrain/Differentials
August 31st, 2011 11:04 AM
Joeypete
August 9th, 2009 05:35 PM
Quick Reply: 1984 transmission oil change
