another one! 1969 delta 88
Old May 17th, 2016, 04:54 PM
  #81
eric66's Avatar
Nice work!
eric66 is offline
Old May 19th, 2016, 01:36 PM
  #82
SeanMiller063's Avatar
Both installed had to put a few more bends in the dipstick tube but its in! Car is running but boy are open headers loud
SeanMiller063 is offline
Old May 19th, 2016, 01:38 PM
  #83
Originally Posted by SeanMiller063
... boy are open headers loud
MDchanic is offline
Old May 20th, 2016, 09:08 AM
  #84
Registered car nut
nonhog's Avatar
Love the big car build. (took my drivers test in Moms 1969 SS427 Impala) Nice work on the headers!
nonhog is offline
Old May 20th, 2016, 08:19 PM
  #85
Here you guys go! Open header video short and sweet. Started on the exhaust system today hoping to scrape up enough time to get it done by Monday.
Old May 20th, 2016, 08:23 PM
  #86
http://s1283.photobucket.com/user/Iv...73qqc.mp4.html
Old May 22nd, 2016, 03:08 PM
  #87
All but 4 clamps will be gone, the garage where i have access to a lift doesn't allow any welding but it was 100X easier to mock it all up and such on the lift so i can take it down in the sections i want welded at home
Old May 22nd, 2016, 09:38 PM
  #88
same but different
don71's Avatar
Don't know how I missed your write up, but hats off to you for making it work. Love these big cars. Look forward to hearing it later.
don71 is online now
Old May 23rd, 2016, 03:39 PM
  #89
eric66's Avatar
Sweet ,great job you put in some hard work. I hope it sound good.You got to do a drive by video!
eric66 is offline
Old May 23rd, 2016, 06:53 PM
  #90
Old May 24th, 2016, 04:32 PM
  #91
Alright, exhaust is 80% done i just need to pipe it out the bumper, dumps right after the axles now. But found out i have a massive power steering leak as well as my water pump is ****. I'm planning on going to an electric water pump and power steering pump started a thread asking pros vs cons of the electric water pump. Also planning on the grand cherokee box swap while I'm in there so i only have to do the lines and such once. Looking into a mazda 3 pump about $75 used off of craigslist where stock replacements range from $55-$299 depending
Old May 24th, 2016, 04:33 PM
  #92
https://classicoldsmobile.com/forums...tml#post922412
Old May 27th, 2016, 01:45 PM
  #93
Well tomorrow is the day, going to the local pick and pull having a 40% off sale in search for a mazda 3 electric power steering pump, hoses, pigtails and also a jeep grand cherokee steering box hopefully with hoses. I may also look for some coolers and hoses trans, pwer steering, oil ect. But it shouldn't be to bad. What else do you guys think?
Old May 31st, 2016, 07:24 PM
  #94
Old May 31st, 2016, 07:28 PM
  #95
I should have some more parts coming in the mail soon! Also i picked up a jeep grand chrokee steering box and still on the hunt for the mazda 3 steering pump.
Old June 18th, 2016, 04:34 PM
  #96
Early fathers day/ birthday gift from the wife!
Some other Parts came in too!
http://IMG_20160602_163155_zpsjezgildc.jpg
Old June 18th, 2016, 04:36 PM
  #97
Got the jeep gc box
Old July 1st, 2016, 06:41 PM
  #98
Well, I won't be using the Mazda 3 pump, the computer on the pump made wiring it to run beyond my skill level. Ended up selling the ones I bought, plus side is I made a small profit from the sales I'll end up with an MR2 or volvo one.
I will be making a fan shroud for the radiator I'll use some aluminum sheet and make some bends.
As far as the over flow bottle I'm thinking of using some 1 Leiter aluminum paint cups for the washer fluid, overflow and steering punp reservoir and mounting them possibly on the fire wall or near the front of the car and plumbing them with either brake line or fuel line. What do you guys think?
Old July 1st, 2016, 06:42 PM
  #99
The under dash wiring is a mess thanks to the P.O. installation of a radio that they didn't wire correctly
Old July 22nd, 2016, 10:45 AM
  #100
Progress started yesterday! tmp_5212-IMG_20160722_112004-1874046028_zpsbv7kydup.jpg
Much more to come as I am still going. I'll have some write up style posts as well here. Thank you guys for looking and the encouragement
Old August 8th, 2016, 10:52 PM
  #101
Well got the car running today! Everythingis operational however a few problems exist.
Problems:
1: I used 40 amp fuse and relay for the steerint pump works however once its at lock i lose the fuse. I bought the provisions to do an 80 amp fuse and 100 amp relay tomorrow so no more issues there.
2: i did the jeep box swap it must have been knocked off center because lock to lock is not even. But again itll be an easy fix
Old August 18th, 2016, 05:16 PM
  #102
So far so good! Waiting on a 124 amp alternator but then it'll be back running!
Old August 18th, 2016, 05:52 PM
  #103
I think you did a lot of good work for essentially zero benefit, but if it makes you happy, that's what it's all about.
The same could be said for what any of us does with our cars, so I'm not really being critical.
I'd like to know how you like driving it once you get it all finished.
MDchanic is offline
Old August 18th, 2016, 06:17 PM
  #104
eric66's Avatar
Keep up the good work.
eric66 is offline
Old August 18th, 2016, 08:23 PM
  #105
You Sir are not wrong. Maybe save 10 to 15hp at peak but overall because it all needed to be changed (leaking waterpump and steering pump, rusty rad) I figured "why not" ha. Only thing that cost much more than a "stock" replacements
I wont 100% know om the steering only because I swapped out for a grand cherokee box at the same time however i hope becaust it is still a hydrolic system it should feel similar and not "numb"
Thank you guys
Old September 25th, 2016, 01:41 PM
  #106
Whats up everybody sorry I've been MIA lots of issues getting the car sorted out, two bad alternators this new one is only putting out 13.10 and its a 140 amp alternator, had a bitch of a time with getting the coolant system worked out ended up just losing the tstat for now hopefully this helps out. Also developed an oil leak on the timing chain cover.
Old October 2nd, 2016, 07:49 PM
  #107
mrolds88's Avatar
Nice car Sean. Lotta work there. I have some cool stuff off of a 69 98 that I parted last year. If your interested hit me up.
mrolds88 is offline
Old November 17th, 2016, 12:25 PM
  #108
Thank you. For now I think I'm okay on parts truth be told im at a crossroads with the car I'm still having electric charging problems i think ive narrowed it down to the battery however car needs other work as well (intake, carb) . Somedays I want to keep it and do a 4 speed with a dana 60 and a pro street style setup with tunnel ram/blower for fun and drive the **** out of it, other days I want to sell it and get a formula vee or ford to actually race.
Old November 17th, 2016, 03:46 PM
  #109
eric66's Avatar
Hang in their bro take a deep breath .Take it one at a time don't get discouraged. I've been saving up to get the 1970 Delta painted and something always come up. The Lativan princess needs to go back to see mother so i can save some money
eric66 is offline
Old November 18th, 2016, 08:53 PM
  #110
Olds442redberet's Avatar
That's going to be pone heck of a sleeper when you're done.
Olds442redberet is offline
Old November 20th, 2016, 12:32 PM
  #111
Thankyou for the kind advice.
Old November 20th, 2016, 01:01 PM
  #112
Thank you it would be awesome to have a full on sleeper a buddy at work is trying to get me to go procharged or turbo to keep it all under the hood but for me Ive always loved the prostreet or gasser style the other day I was thinking of how different it would be to do a gasser delta just tunnelram lifted up front open headers ive seen wagons, trucks and impalas some 50s 88's too
Old November 20th, 2016, 07:06 PM
  #113
A quick photo hack job of a gasser 69
Old January 22nd, 2017, 04:08 PM
  #114
Alright, car is finally running good! I was going through alternators like nobodys buisness and thats because the exciter wire needed a 100ohm 1/4 resistor seems the alt light was not enough. Went with a cs144 alternator 140amp for the juice. The Electronic Water Pump is working great the Electric Fans working great the radiator is working well, the electric power steering pump is well different... it needs some more fine tuning I need to put another bracket on the alternator and theres a small air leak somewhere in the system I need to find as well as when I installed the jeep steering box it must have not been centered as I thought it was so ill have to fix that but not a big issue.
Old January 22nd, 2017, 07:01 PM
  #115
eric66's Avatar
Wow sounds like you been very busy.When you get a chance post some pictures.
eric66 is offline
Old January 23rd, 2017, 06:07 PM
  #116
Alright guys, theres some cleaning up to do and there are some write ups I would like to do I have some better pictures of however here are some for now
Old January 23rd, 2017, 06:39 PM
  #117
Old School Olds
tru-blue 442's Avatar
Nice work Sean! Love the color. I didn't know Chevy made a rally on 5X5.
Do you have a side shot?
tru-blue 442 is offline
Old January 23rd, 2017, 07:23 PM
  #118
I honestly dont think they did I popped a center cap off and fitment left something to be desired for sure.
Old January 23rd, 2017, 07:41 PM
  #119
eric66's Avatar
Sweet I have some pictures.of mine while it being painted.
eric66 is offline
Old January 28th, 2017, 10:58 AM
  #120
Does anyone know where to get rear gears and maybe a Posi or some type of spool style for the rear of these cars?
When I first joined the board with my 69 I remember seeing a a few guys however I can't find them right now.
Quick Reply: another one! 1969 delta 88
